barry 719 bw Posted July 16, 2023 Posted July 16, 2023 can someone please tell me where to locate the points on ts50 Quote
Bianco2564 Posted July 16, 2023 Posted July 16, 2023 Hello and welcome. From what I can see,its under the LH engine cover behind the flywheel/magneto. Should be a couple of windows in the flywheel you look through to access the points. Probably need a puller to get the flywheel off, the cam to open the points is usually on the flywheel if its similar to other types. Quote
Old-codger Posted July 16, 2023 Posted July 16, 2023 It will be under the alternator cover on the nearside of the bike as you sit on it. its on the end of the crank. Quote
