Recommend me a crimping tool.
Go to solution Solved by Guest,
Posted (edited)
10 hours ago, megaross said:
I use cheap ratchet crimpers with interchangeable jaws (and hydraulic crimpers for battery terminals, to be a technical dick) with unsheathed crimps, I then solder and heatshrink the connector and smear in a bit of dielectric grease for good measure.
Unless of course waterproofing is required, in which case I use either the crimp and slide type you pick up from electronics suppliers or else straight solder and shrink johnny if I don't care about the disconnect.
When you say hydraulic crimpers, this type will do?
https://www.ebay.co.uk/itm/265969512190
Edited by onesea
Yeah for battery terminals and the like those cheap eBay boys do the business.
Obviously too big for normal wiring but for making big f**k off chonk cables to upgrade wiring they're brilliant.
