I'm wondering if a compression test would give more information on this matter? Or even if the piston was naffed.. would it still show high compression?
-Also, never really messed about with the power valve.. dont know what to check for on that one :)
my CCM only does a ton. :cry:
Id check power valve is opening fully, assuming the carburation etc is ok, Id guess piston damage. You have got a good spark plug in there havent you??
compression test on a 2 stroke don't mean a great deal.
is this a problem that just happened out of the blue? is it possible the ignition timing is wrong?
