Pie man Posted April 7, 2024 Posted April 7, 2024 I thought I would try the Rhinowalk 30L Luggage, cheap as chips with quality to match  Not really a review because I haven't actually used it yet. It arrived, well packaged. The first thing I noticed was the polyester is not the same quality/weight as Kreiga, more like a builders 1 tonne bulk bag It has a neat document pocket with a waterproof zip! and on the other side it rubber netted back, probably to stop it moving around, but it could also hold a map etc. It straps to the bike through buckles and hoops, just like Kreiga, but comes with two optional shoulder straps, however the plastic clip connectors do not integrate with Kreiga. It has a roll top so theoretically it should keep the rain out. I'm impressed, for something as cheap as it was £38, but I know you get what you pay for.  I have packed it with a weeks worth of clothing etc and it holds far more than my Kreiga 30L. Fits easily on the back of the bike, secured by the 4 straps, however; I would take additional Rock Straps just in case. Its also says waterproof, I think I would add my waterproof external rucksack cover.  The roads and motorways in the UK are busier than ever, so, I have decided to leave the Bumot luggage at home this year and travel with the tail pack and backpack. I will provide feed back after it has been used for the trip.   1 1 Quote
veracocha Posted April 7, 2024 Posted April 7, 2024 I have been using that very bag for six months, I can't fault it. To make things a little more solid I placed a washing up bowl inside which makes getting access to things a bit easier, I just slide the bowl outwards. I have not had any water ingress so far. 2 1 1 Quote
Pie man Posted April 7, 2024 Author Posted April 7, 2024 1 hour ago, veracocha said: I have been using that very bag for six months, I can't fault it. To make things a little more solid I placed a washing up bowl inside which makes getting access to things a bit easier, I just slide the bowl outwards. I have not had any water ingress so far. Brilliant. I like it 1 Quote
