2024 Husqvarna 701 Enduro.
2024 Husqvarna 701 Enduro. (Husqvarna/)
Strong platforms stand the test of time, and the one that the 701 Enduro is based on has done just that. This single-cylinder dual sport can serve many purposes from lightweight ADV to heavyweight enduro, which gives it a ton of versatility.
Its 693cc SOHC single is shared with no less than five other models including its Supermoto sibling under the Husqvarna banner. It is liquid-cooled, has electric starting, fuel injection, and features ride-by-wire throttle, which allows multiple ride modes. It also has lean-sensitive ABS and traction control.
A steel-trellis frame and composite subframe with integrated fuel tank anchor the chassis. Suspension consists of a WP 48mm Xplor fork with 9.8 inches of travel in the front and a linked WP shock with identical travel. Wheels measure 21 inches in front and 18 inches at the rear with 90/90-21 and 140/80-18 rubber, respectively. Brembo brakes with Bosch ABS handle braking duty.
The 2024 Husqvarna 701 Enduro is $12,999 in the single white color.
  • <a href="https://www.cycleworld.com/honda/xr650l/"><b>Honda XR650L, $6,999</b></a>
  • <a href="https://www.cycleworld.com/kawasaki/klr650/"><b>Kawasaki KLR650, starting at $6,899</b></a>
  • <b>2025 </b><a href="https://www.cycleworld.com/story/buyers-guide/2020-suzuki-dr650s/"><b>Suzuki DR650S, $7,199</b></a>
  • <a href="https://www.cycleworld.com/story/buyers-guide/2020-ktm-690-enduro-r/"><b>KTM 690 Enduro R, $12,999</b></a>
  • <a href="https://www.cycleworld.com/story/motorcycle-news/gasgas-es-700-first-look-2023/"><b>GasGas ES 700, $12,699</b></a>
News and Reviews
  • <a href="https://www.cycleworld.com/story/bikes/2021-husqvarna-701-enduro-lr-dyno-test/"><b>Husqvarna 701 Enduro Dyno Test</b></a>
2024 Husqvarna 701 Enduro Claimed Specs
MSRP: $12,999
Engine: SOHC, liquid-cooled single; 4 valves
Displacement: 693cc
Bore x Stroke: 105.0 x 80.0mm
Compression Ratio: N/A
Fuel System: Keihin EFI w/ 50mm throttle body; ride-by-wire
Clutch: Wet, multiplate slipper; cable operation
Frame: Chromoly steel trellis
Front Suspension: WP 48mm Xplor fork, compression and rebound adjustable; 9.8 in. travel
Rear Suspension: WP linked monoshock, fully adjustable; 9.8 in. travel
Front Brake: 2-piston Brembo caliper, 300mm disc w/ ABS
Rear Brake: 1-piston Brembo caliper, 240mm disc w/ ABS
Wheels, Front/Rear: Spoked; 21 in./18 in.
Tires, Front/Rear: 90/90-21 / 140/80-18
Rake/Trail: 27.7°/NA
Wheelbase: 59.25 in.
Ground Clearance: 10.6 in.
Seat Height: 36.4 in.
Fuel Capacity: 3.4 gal.
Wet Weight: 322 lb.
Are these reviews etc automated? A correctly formatted, manual version would be vastly more pleasant to read rather than picking through the various html with squashed pics
Posted (edited)
Admin is a poster bot. Im holding out for Admin 2.0.
Edited by bonio
  • Thanks 1
