claire Posted October 16, 2024 Posted October 16, 2024 My son has just bought a yellow 125cc bluroc legend bike and so far had nothing but trouble. So first it's stopped working so bought new battery and changed the starter relay worked perfect after that untill he got to the end of the road and it shut off the engine when he down geared the bike to stop. So we unplugged the kickstand and it managed a 10 minute ride. Untill today when he got to the end of the road again and the bike cut out and wouldn't start up again. We have all lights except high beam and the horn sounded very dull. The battery as Is only 3 weeks old does anyone have a solution for me before I burn it to the ground #Stressed mum Quote
Fiddlesticks Posted October 16, 2024 Posted October 16, 2024 Had to Google that one. Nice looking bikes. Seems like a few different things. The horn might just be in need of replacing (less than a tenner - they do tend to go) if you have a multimeter you can test the circuit. High beam - fuse/bulb? Any more detail on how the engine is cutting out? Saw this in Reddit, but not sure if it sounds like the same issue. Quote
Old-codger Posted October 17, 2024 Posted October 17, 2024 15 hours ago, claire said: My son has just bought a yellow 125cc bluroc legend bike and so far had nothing but trouble. So first it's stopped working so bought new battery and changed the starter relay worked perfect after that untill he got to the end of the road and it shut off the engine when he down geared the bike to stop. So we unplugged the kickstand and it managed a 10 minute ride. Untill today when he got to the end of the road again and the bike cut out and wouldn't start up again. We have all lights except high beam and the horn sounded very dull. The battery as Is only 3 weeks old does anyone have a solution for me before I burn it to the ground #Stressed mum Hi there I understand your pain but if you brought this from a dealer you need to inform them to come and collect the bike and start advising them that under the consumer rights act 2015 the product has to be of reasonable quality, fit for purpose and last a reasonable amount of time. If it was mine (and lukily I would never buy chinese crap) and you brought it within the last 30 days you should be demanding your money back. If its a private sale you are stuck with it sorry. Quote
RideWithStyles Posted October 17, 2024 Posted October 17, 2024 (edited) Sounds like Within that short time/distance Might be a fuel/ vacuum problem….first if the breather pipe in the fuel tank is blocked or trapped it starves the engine. when at idle start the bike and leave or rev it a bit till it stalls as it normally does now, try to quickly start it again if not luck open the fuel cap, if a load of air is heard and felt rushing in ok, then put the cap back on, start the bike again, does it start very quickly or actually starts? if so…. in the tank (underneath) their will be two thick rubber main pipes, one for the injection system (engine) and another probably small is the breather that is a long pipe that leads to the bottom of the bike and dangles freely or is connected to a large black canister that then doesn’t seem to connect to anything (that is a vapour trap). Check that smaller pipe that breather pipe if it has kinks of any kind / trapped etc along the line- that can be a problem that is easy to do by a mechanic . while there Check under the fuel cap / neck of the of tank, there will be a very small hole that is to drain the water or fall out that fills full of crap. Edited October 17, 2024 by RideWithStyles Autocorrect Quote
