Guest Posted February 18, 2009 Posted February 18, 2009 Hi,I've recently bought a used Honda bike from a dealer having owned a car for most of my life. As a result, I've got some car oil left over but obviously have no car. Can I use this car oil in my bike? As I'm relatively new to owning a bike, I'm not sure on the ins and outs of what can and can't be used, so thought this might be a good place to ask.Cheers,Chris the Biker. Quote
Guest philgale Posted February 18, 2009 Posted February 18, 2009 welcome to the forum....i was told yesterday by the guys in the suzuki dealer not to, something to do with the clutch being wet on a bike and dry on a car (i dont know maybe they were just selling me there oil) Quote
Guest Posted February 18, 2009 Posted February 18, 2009 I was tempted to do something similar when I forst got my bike, having 40L of car 10W40 in the garage, but have done a little reading (and posting on this board) and its advised not to becuase there are components added to car oil to reduce wear... these will cause clutch slip on your bike since it shares the same oil as your gearbox.Other people have used it to no ill-effect, but I figured for the relatively small expense of some oil I'd prefer to use the right stuff. Quote
rollazuki Posted February 18, 2009 Posted February 18, 2009 bike oil generally is a short chain lubricant. This is used, since a bike gearbox and clutch are both in the oil. Car oil usually isnt, and shouldnt be used.Also most car oils have friction modifiers in them that may cause clutch slip.Having said all that, I was once told by a 'Morris' lubricants rep, that the synth oils were the same stuff.Id use as bike oil, play it safe. After all, a car doesnt spin to 10000 rpm+ does it!?!Rolla Quote
Voodoo Posted February 18, 2009 Posted February 18, 2009 I use car oil all the time on all the bikes I've ever owned. I've never had the clutch slip due to oil. Quote
Guest akey Posted February 18, 2009 Posted February 18, 2009 bike oil generally is a short chain lubricant. This is used, since a bike gearbox and clutch are both in the oil. Car oil usually isnt, and shouldnt be used.Also most car oils have friction modifiers in them that may cause clutch slip.Having said all that, I was once told by a 'Morris' lubricants rep, that the synth oils were the same stuff.Id use as bike oil, play it safe. After all, a car doesnt spin to 10000 rpm+ does it!?!Rolla Have a look at how much you would save v's the cost of new clutch and a full drain and flush of the oil system then ask yourself is it worth it.IMHO I only ever use bike oil. Quote
Guest Posted February 18, 2009 Posted February 18, 2009 Same here, if its worth doing, its worth doing right. Quote
cruz Posted February 18, 2009 Posted February 18, 2009 Of course if your bike runs a dry clutch there won't be a problem. always used a 20/50 in my Guzzi's, but now with a wet clutch I use 10/40 bike oil. Quote
Guest Posted February 22, 2009 Posted February 22, 2009 I've used Duckhams car oil in my Harley Sportster for the last 7 years with no problems, but I do an oil/filter change every year and the transmission/wet clutch runs in its own oil bath (for which I use bike transmission oil).Bill Quote
