Guest Posted May 27, 2009 Posted May 27, 2009 Can any one help,Came out and started my Yami FZR600 and my indicators don't work, also my hazard warning lights are not working, worked OK earlier. However when I put the alarm on the indicators do work? Is it a fuse, or has the flasher relay gone, if so how do I change either the fuse or the relay?Need help, thanks! Quote
Korben Posted May 27, 2009 Posted May 27, 2009 Hi MateWelcome to the forum!! Drop into newbies and introduce yourself!! Not sure about the indicators, but from what you say it sounds like the alarm system is causing the problem...Someone more knowedgable may know more though mate. Quote
Guest Posted May 27, 2009 Posted May 27, 2009 Can any one help,Came out and started my Yami FZR600 and my indicators don't work, also my hazard warning lights are not working, worked OK earlier. However when I put the alarm on the indicators do work? Is it a fuse, or has the flasher relay gone, if so how do I change either the fuse or the relay?Need help, thanks! take off the seat and you should find the relay.. its obviously not bulbs and wiring if your alarm lights them.. it will probably be mounted behind a side panel, they like to keep them out of the way.. could be its worked loose... Quote
