Colin the Bear Posted June 13, 2011 Posted June 13, 2011 Apart from being illegal, a signal that says "I am a stationary hazzard" applied to a moving vehicle is confusing. A big sign saying on tow is the norm. A beacon isn't hazzards Quote
Bogof Posted June 13, 2011 Posted June 13, 2011 Apologies, I assumed it was under the same principle of slow moving vehicles such as tractors using flashing amber lights as a warning. I think hazrds when towing are a good idea. Tractors, breakdown trucks and the like should not use orange beacons when moving.I think hazards are a right royal pain in the arse. People seem to only use them when they park in a stupid place, as if that allows them to do so with impunity.Also, when they are used when a car is parallel parked, you can't SEE the left one, so you think they are indicating right to pull out in front of you so end up slowing down for no good reason! They waste as much fuel as bicycles and should be banned from the road when I'm using it! GRRRR! Quote
Aaron Posted June 24, 2011 Posted June 24, 2011 Apologies, I assumed it was under the same principle of slow moving vehicles such as tractors using flashing amber lights as a warning. I think hazrds when towing are a good idea. They aren't a good idea because then you can't indicate effectively. If you ever get towed by an AA recovery vehicle they will tell you NOT to use hazzards and to indicate as and when the towing vehicle does. Quote
Aaron Posted June 24, 2011 Posted June 24, 2011 High beam will dazzle car drivers... You need to invest on some shades if you get dazzled during the daytime!Bikes come with a 'passing' trigger specifically for that purpose. Quote
