Jerry Can Posted September 20, 2009 Posted September 20, 2009 Sounds weird I know but........Does anyone know what the round piece of metal is for that's between the tail light and fuse box?Its mounted on rubber and is round with a diameter of about 2 inches and about an inch and half thick. Quote
Guest Posted September 20, 2009 Posted September 20, 2009 picture?http://i250.photobucket.com/albums/gg250/simonevans73/untitled2.jpgis the metal thing on here, in front of the fuse box, if so its the seat locator and locking mechanism.. if not, can you post a picture.. Quote
Jerry Can Posted September 21, 2009 Author Posted September 21, 2009 Hello,Sorry cant take a pic unless the whole rear plastic surround is removed, Its just a bit further back from that circle you have drawn. It's not connected to anything except the frame with 2 nuts.It's just solid metal rubber mounted. Quote
Alex Gold Posted September 21, 2009 Posted September 21, 2009 The mount for the stop light bulb? Quote
Guest Posted September 21, 2009 Posted September 21, 2009 is there anything on the opposite side of it..? Quote
Grumpy Old Git Posted September 21, 2009 Posted September 21, 2009 It's just the extra weight required to stop you out accelerating a Blackbird!!1 Quote
Jerry Can Posted September 23, 2009 Author Posted September 23, 2009 No it's not attached to anything except the frame, I had it off the other day when i removed the entire rear surround to sort a number plate bracket.It's odd, just seems like a counterweight but only weighs about a kilo if that Quote
Guest Posted September 23, 2009 Posted September 23, 2009 No it's not attached to anything except the frame, I had it off the other day when i removed the entire rear surround to sort a number plate bracket.It's odd, just seems like a counterweight but only weighs about a kilo if thatTake it out, save lugging round an extra KG... but keep just in case.. Quote
Jerry Can Posted September 27, 2009 Author Posted September 27, 2009 Yea that's it...the top one.But how does that work? It's in a right pain of a position if you wanna take out ya back lights Quote
Guest Posted September 27, 2009 Posted September 27, 2009 its like your bar ends it reduces vibration, by being heavy. prob stops bulbs blowing etc.. Quote
