archiec Posted February 14, 2010 Share Posted February 14, 2010 Hi thereAnyone got tips on removing surface rust spots from chrome that have appeared over the winter as my bike was outside but under a cover, I want to clean it up before it gets more serious. Quote Link to comment Share on other sites More sharing options...
Guest Posted February 14, 2010 Share Posted February 14, 2010 If its only slight rust then try using a bit of metal polish,if you havnt got any Apply a little 3 in 1 oil to some 000 grade wire wool,once rust is under the chrome then its the start of the rot,keep on top of it unless you want to see it get worse Quote Link to comment Share on other sites More sharing options...
Guest Posted February 14, 2010 Share Posted February 14, 2010 kitchen foil and autosol/metal polish, scrunch the foil and rub the polish in with it. Quote Link to comment Share on other sites More sharing options...
archiec Posted February 14, 2010 Author Share Posted February 14, 2010 Thanks guys Quote Link to comment Share on other sites More sharing options...
Mk5Centurion Posted February 17, 2010 Share Posted February 17, 2010 kitchen foil and autosol/metal polish, scrunch the foil and rub the polish in with it.Not heard that one before....will have to give it a go Quote Link to comment Share on other sites More sharing options...
