Dale. Posted April 2, 2010 Share Posted April 2, 2010 this morning i came to put the bike into neutral from first. Its really tough and it skipped straight into 2nd it will keep doing this even kicking down into neutral from 2nd after a few times of kicking up and down it finally slips straight in turn the engine of for 30 secs then back on i will have the problem again. Ive tryed rolling the bike back and forward or do you think its because it being dead cold this morning.So problem isI have to change from 1st to second a few times before the lever will just slip into neutral.gear changes are fine lever is slack enough only happend this morning not had this problem before Quote Link to comment Share on other sites More sharing options...
JimiB Posted April 2, 2010 Share Posted April 2, 2010 Maybe your chrome's not polished enough . happens to me all the time. Quote Link to comment Share on other sites More sharing options...
JimiB Posted April 2, 2010 Share Posted April 2, 2010 By tough to you mean hard to move the gear lever? Quote Link to comment Share on other sites More sharing options...
Guest Posted April 2, 2010 Share Posted April 2, 2010 It could just be your technique.... if not its something thing to do with worn something (lol) i think and so need assistance from WF...again ... Quote Link to comment Share on other sites More sharing options...
Guest Posted April 2, 2010 Share Posted April 2, 2010 It could just be your technique.... if not its something thing to do with worn something (lol) i think and so need assistance from WF...again ... poor walney. He will be pleased Quote Link to comment Share on other sites More sharing options...
archiec Posted April 2, 2010 Share Posted April 2, 2010 Probably just your technique Dale don't worry too much about it, you can always swich off in gear and start with the clutch in if you need too Quote Link to comment Share on other sites More sharing options...
Guest Posted April 2, 2010 Share Posted April 2, 2010 stay in first with the clutch pulled in.. its technique, sometimes its straight in, othertimes it needs a little gentle persuasion...the lever into neutral you dirty dirty minded reader... Quote Link to comment Share on other sites More sharing options...
Guest Posted April 2, 2010 Share Posted April 2, 2010 stay in first with the clutch pulled in.. its technique, sometimes its straight in, othertimes it needs a little gentle persuasion...the lever into neutral you dirty dirty minded reader... actually, i wasn't thinking of anything dirty until i read that sentence !!! Quote Link to comment Share on other sites More sharing options...
cypek Posted April 2, 2010 Share Posted April 2, 2010 Don't worry too much about it. I too have to jump between 1st and 2nd a few times before I find neutral I'm getting better with time as I'm getting used to my bike and the same will be with you Keep riding Quote Link to comment Share on other sites More sharing options...
Dale. Posted April 3, 2010 Author Share Posted April 3, 2010 Don't worry too much about it. I too have to jump between 1st and 2nd a few times before I find neutral I'm getting better with time as I'm getting used to my bike and the same will be with you Keep riding That isnt my problem!!! My problem was you have to lift your foot up lightly however it wouldnt lift unlike it usally does so you have to add some more force and it just jumps straight into second. Just seemed to be the cold so as when i came home from work sat on the bike and straight into neutral. Quote Link to comment Share on other sites More sharing options...
