JimiB Posted May 24, 2010 Share Posted May 24, 2010 Ok so i've got front and rear drum brakes on my cg125 copy. .http://sphotos.ak.fbcdn.net/hphotos-ak-ash1/hs518.ash1/30522_1241330087204_1647877235_516928_969038_n.jpghttp://sphotos.ak.fbcdn.net/hphotos-ak-ash1/hs518.ash1/30522_1241330247208_1647877235_516930_401569_n.jpgBut there so so so very loose?I've tightened them up to the point where i probably think they may actually be unsafe so i got new pads for them . went to changeold to new pads but the pads aren't worn at all compared to the new ones. what can i do ?http://sphotos.ak.fbcdn.net/hphotos-ak-snc3/hs538.snc3/30522_1241330207207_1647877235_516929_4702477_n.jpga friend suggested taking this of and moving it to the left a little. Would this work?When i say this i dont mean the nuts to tighten the chain i mean the break lever thingy behind it. Like take it off and angle it more.help would be much appreciated. thank you very much in advanced.maybe i should of cleaned the bike first before taking photos.... Also how easy/hard would it be to put disc brakes on it ? Quote Link to comment Share on other sites More sharing options...
JimiB Posted May 24, 2010 Author Share Posted May 24, 2010 I've done what my friend suggested to the back brake and it seems to have worked . though its still not tight. Just the spring isnt compacted to death. Quote Link to comment Share on other sites More sharing options...
Guest Posted May 24, 2010 Share Posted May 24, 2010 yep that works, but remember to return to normal when fitting new pads.. otherwise they might not fit. or be on when off. Quote Link to comment Share on other sites More sharing options...
JimiB Posted May 24, 2010 Author Share Posted May 24, 2010 I was expecting you to answer.. CheersGonna do it to the front now. Thank you muchhos. Quote Link to comment Share on other sites More sharing options...
