Aaron Posted June 12, 2010 Share Posted June 12, 2010 HI. I just blew up my exhaust, or something. I pulled out to overtake, pinned the throttle, and it all went loud and poppy. I rode all the way back home at 20mph because of the noise, and over bumpy ground i could hear metallic rattling and clanging behind the massive exhaust noise.I cant see that much, and i've gotta dash off to a wedding in 10 minutes :sHere's a picture. I dont know ho wwell it shows up, but i can see a gap in the pipe where the arrow points. And when i rev it i can see dust blowing around directly underneath on the road, in addition to the usual around where the silencer is.Does anyone know if this sounds about right? and is it safe to ride to get fixed? (if warrenty covers it its about 30 miles away).Also, if it sounds like that's all it is, is it expensive?Thanks Quote Link to comment Share on other sites More sharing options...
spunky1976 Posted June 12, 2010 Share Posted June 12, 2010 if thats a joint could be a blown gasket otherwise its a hole in the pipe. if its a hole you could try gun gum and a sleeve or get it welded maybe not sure how this would work on a bike only done it on cars before Quote Link to comment Share on other sites More sharing options...
Guest Posted June 12, 2010 Share Posted June 12, 2010 could be the clamp is shot, undo the clamp, and endcan and reseal with holts firegum, and refit with a new clamp, when you remove the back box / end can you should see if theres any damaged broken pieces, not advisable to do in a suit, prior to a wedding tho' Quote Link to comment Share on other sites More sharing options...
Aaron Posted June 12, 2010 Author Share Posted June 12, 2010 Looks like something seperated rather than a hole. Bikes only 3 months old. I'll have a closer look when I get back tomorrow. Cheers guys. Quote Link to comment Share on other sites More sharing options...
Jixerman Posted June 12, 2010 Share Posted June 12, 2010 Get it done under Warranty??? Quote Link to comment Share on other sites More sharing options...
Aaron Posted June 12, 2010 Author Share Posted June 12, 2010 Get it done under Warranty???If it's not considered a consumable then I can if it's safe to ride that far. Thank goodness for iPhones to see me through the wedding of 2 people I don't know Quote Link to comment Share on other sites More sharing options...
eastanglianbiker Posted June 12, 2010 Share Posted June 12, 2010 if the bike is only 3 months old ring the dealer and see if they will collect the bike and sort out the repair as it isnt road legal with exhaust like that Quote Link to comment Share on other sites More sharing options...
spunky1976 Posted June 12, 2010 Share Posted June 12, 2010 consumable or not after 3 months they surely have to fix it under warranty Quote Link to comment Share on other sites More sharing options...
Guest Posted June 12, 2010 Share Posted June 12, 2010 Pretty sure that'd be the case. Don't touch owt til you find out. Quote Link to comment Share on other sites More sharing options...
Aaron Posted June 13, 2010 Author Share Posted June 13, 2010 Hi. Got some better photos, and now it's cold i could have a wiggle. Looks like it's just sheared rather than any kind of seal or joint being broken. I had a quick google and it sounds like a common problem :s Oh well. I'll have to call up the dealer on monday. Quote Link to comment Share on other sites More sharing options...
Aaron Posted June 14, 2010 Author Share Posted June 14, 2010 They've ordered some new pipes. Should be in by wednesday. Quote Link to comment Share on other sites More sharing options...
eastanglianbiker Posted June 14, 2010 Share Posted June 14, 2010 hope you have made sure with them that this is at no cost to you for new part and the labour to replace it Quote Link to comment Share on other sites More sharing options...
Aaron Posted June 14, 2010 Author Share Posted June 14, 2010 hope you have made sure with them that this is at no cost to you for new part and the labour to replace it Well when i phoned i explained that, but the woman put me through to 'servicing'. So perhaps he just picked up the phone and wasn't aware that i wanted it done under warranty. When he calls me back to say they got the pipes i'll double check. TBH, after reading about it being a common fault, i can't see how they could refuse. He asked how many miles i'd done, so maybe that's an indicator that he's thinking about warranty conditions. Anyway after just 3 months and 2600 miles i'll get it sorted at no cost one way or another Other posts i've googled, regarding the same problem and others, all sounded like Kawasaki seem to be fairly good at that sort of thing. Fingers crossed.I'm hoping that they can fix it while i wait and will give me a different bike to go for a joy ride on while i wait. A nice zx 6 or something Quote Link to comment Share on other sites More sharing options...
Aaron Posted June 15, 2010 Author Share Posted June 15, 2010 Getting new pipes fitted in the morning under warranty. Now i just hope that that really is the problem. I just said "blah blah blah" like i know what i'm talking about and he said "ok, i'll order some pipes for you". Lol. Quote Link to comment Share on other sites More sharing options...
