pete_m_j Posted June 26, 2010 Share Posted June 26, 2010 Hi guys, can you help. Bandit 650 s k8, at 40 ish mph the handle bars will gently wobble by about 1 inch, (not a vibration), back and forth from left to right. You only see it if you have a really loose grip. At about 55 to 60 it seems to go, and over 60 solid as a rock. Below 40 nothing also.Don't know if its tyre, or wind or something else.Bike is new to me and it does have a new front bridgestone.Advice is always welcomed please Quote Link to comment Share on other sites More sharing options...
eastanglianbiker Posted June 26, 2010 Share Posted June 26, 2010 few things to check make sure the tyre has sat on the bead correctly all the way round chek wheel bearings headrace bearings was the wheel balanced when new tyre fitted few things to check Quote Link to comment Share on other sites More sharing options...
spunky1976 Posted June 26, 2010 Share Posted June 26, 2010 you ocould have lost a balancing weight from the wheel rim. Quote Link to comment Share on other sites More sharing options...
fazerboy Posted June 26, 2010 Share Posted June 26, 2010 you sure the tyre is new?could be a worn tyre,incorect inflation,lost balance weight...take it to a garage and just get em 2 check it for you. Quote Link to comment Share on other sites More sharing options...
Grumpy Old Git Posted June 29, 2010 Share Posted June 29, 2010 Definately a balance problem - Take the wheel to a garage and get it checked. Also check for uneven tyre wear. Quote Link to comment Share on other sites More sharing options...
Anthony Posted June 30, 2010 Share Posted June 30, 2010 i know what you mean, i had that feeling on my bandit6, turned out to be a slightly deflated tyre and worn head bearings, cheap fix and brought the bike back to life. Its an un-nerving feeling so get it sorted before the summer "thrash" in the sun xD Quote Link to comment Share on other sites More sharing options...
Jimmi_929RR Posted June 30, 2010 Share Posted June 30, 2010 Another vote for steering head bearings. Had the same problem on my Bandit and it was this- especially noticeable if you take your hands totally off the bars. Quote Link to comment Share on other sites More sharing options...
Guest Posted July 2, 2010 Share Posted July 2, 2010 im gonna go for a bearing fault as well Quote Link to comment Share on other sites More sharing options...
Guest Posted July 2, 2010 Share Posted July 2, 2010 .................. would a steering head bearing be warranty on an 08 bike ? might be worth checking with your local dealer..... Quote Link to comment Share on other sites More sharing options...
