nman1 Posted March 9, 2011 Share Posted March 9, 2011 Deff up for the 27th. Will look out for times and meeting place for ride over there.Not heard about the usual Rutland Run that I`ve been on these past two years. I don`t think the organiser gets on here anymore. Quote Link to comment Share on other sites More sharing options...
Ash Posted March 9, 2011 Share Posted March 9, 2011 The CBR is starting to get there, but I reckon it will be a good month or two before I'm out again Ride safe everyone Quote Link to comment Share on other sites More sharing options...
acemastr Posted March 9, 2011 Author Share Posted March 9, 2011 If you need a hand Ash let me know Quote Link to comment Share on other sites More sharing options...
Ash Posted March 10, 2011 Share Posted March 10, 2011 If you need a hand Ash let me know Will do cheers bud, How did you get on with fitting that tail light? Quote Link to comment Share on other sites More sharing options...
Guest Posted March 10, 2011 Share Posted March 10, 2011 The CBR is starting to get there, but I reckon it will be a good month or two before I'm out again Ride safe everyone much left to do? If we all muck in, could get it road worthy within a couple of hours (if you've all the parts!), I've a socket set and mini torque wrench that are awaiting their first proper use! Quote Link to comment Share on other sites More sharing options...
Ash Posted March 10, 2011 Share Posted March 10, 2011 The CBR is starting to get there, but I reckon it will be a good month or two before I'm out again Ride safe everyone much left to do? If we all muck in, could get it road worthy within a couple of hours (if you've all the parts!), I've a socket set and mini torque wrench that are awaiting their first proper use! When it's at that stage I would certainly appreciate the help! It need's a check over, engine cover and fluids replaced, brake fluid replaced and a service before I can start cosmetic's though Quote Link to comment Share on other sites More sharing options...
acemastr Posted March 10, 2011 Author Share Posted March 10, 2011 Speaking of torque wrench, i need to tighten my chain (again...), and i stripped the cogs in my ratchet doing it up last time, mind if i steal it for 5mins one day in the near future?I didn't put it in Ash, at the time it was cold and i dind't fancy splicing into my indicator wiring, it's a doddle to fit, but the splicing seems a bit iffy. Plus i don't have any resistors for the LED'ness of it (it might flash at a million miles an hour) Quote Link to comment Share on other sites More sharing options...
acemastr Posted March 10, 2011 Author Share Posted March 10, 2011 The CBR is starting to get there, but I reckon it will be a good month or two before I'm out again Ride safe everyone much left to do? If we all muck in, could get it road worthy within a couple of hours (if you've all the parts!), I've a socket set and mini torque wrench that are awaiting their first proper use! When it's at that stage I would certainly appreciate the help! It need's a check over, engine cover and fluids replaced, brake fluid replaced and a service before I can start cosmetic's though Engine cover and fluids are a 20min job, brake fluid not so quick but will be fine with a bleed kit, and that's pretty much all of the service done bar air filter and plugs, maybe an hour to get to them? I've taken most of my bike apart so far so know my way around fairly well now. Can pop over whenever and give you a hand. Quote Link to comment Share on other sites More sharing options...
Guest Posted March 10, 2011 Share Posted March 10, 2011 mind if i steal it for 5mins one day in the near future? Yeah that's fine, it's what we used to untighten the nut on the single swing arm of Ash's VFR when that needed it's chain tightening. (it was a big one, 40-120Nm, I've also bought a 5-25Nm one for aluminium engine bits)If you've not go rid of the CBR by easter as well Aaron - I'll get a trailer (or trailOR if you're american - celebrity juice) and will bring it to my garage and we can strip it down - I'll be on 11 days holiday with the mrs back at uni, what else do i have to do?! Quote Link to comment Share on other sites More sharing options...
Ash Posted March 10, 2011 Share Posted March 10, 2011 I know a motorcycle mechanic in Sawtry who is going to help me get it road worthy, but then I may need your guy's help with fairing's, lever's, exhaust, tail lights etc Quote Link to comment Share on other sites More sharing options...
acemastr Posted March 10, 2011 Author Share Posted March 10, 2011 I know a motorcycle mechanic in Sawtry who is going to help me get it road worthy, but then I may need your guy's help with fairing's, lever's, exhaust, tail lights etc But the work involved with fluids/engine covers is so simple, you just need a gasket for the engine cover, did it put a hole in it or just scratch?And cheers Dave, is that the same 11 days in April (all the bank holidays etc) that I have off? Quote Link to comment Share on other sites More sharing options...
Ash Posted March 10, 2011 Share Posted March 10, 2011 Put a crack in it mate, and it's ok, the guy is a family friend and doing it himself, not at a garage. Quote Link to comment Share on other sites More sharing options...
acemastr Posted March 10, 2011 Author Share Posted March 10, 2011 Don't run it until the oil's been changed, could be anything floating about Quote Link to comment Share on other sites More sharing options...
iluvbikes Posted March 10, 2011 Share Posted March 10, 2011 We need to start going on rides again, I went out today, ended up following a bloke on a blade who... to say the least... was far more experienced than me. bloody lost me on every corner and i was bloody right over.You lot need to stop being wimps about it being cold!were are u from ? Quote Link to comment Share on other sites More sharing options...
acemastr Posted March 10, 2011 Author Share Posted March 10, 2011 Huntingdon, but i was at Taz's (Wheels) and we bumped into eachother again going through Monks Wood Quote Link to comment Share on other sites More sharing options...
iluvbikes Posted March 10, 2011 Share Posted March 10, 2011 Huntingdon, but i was at Taz's (Wheels) and we bumped into eachother again going through Monks Woodmiles from me i was gona say id meet ya some time for a ride somwere but abit far lol Quote Link to comment Share on other sites More sharing options...
Guest Posted March 10, 2011 Share Posted March 10, 2011 And cheers Dave, is that the same 11 days in April (all the bank holidays etc) that I have off? the one and the same!! Quote Link to comment Share on other sites More sharing options...
Seabluegal Posted March 10, 2011 Share Posted March 10, 2011 There's a lot of technical talk going on here... Quote Link to comment Share on other sites More sharing options...
Guest Posted March 11, 2011 Share Posted March 11, 2011 braintree has the best roundabouts apparently, nicely cambered well maintained and fairly empty, or there is always the magic roundabout in peterborough if you dont fancy a hack down to BT Quote Link to comment Share on other sites More sharing options...
Guest Posted March 20, 2011 Share Posted March 20, 2011 I'm up for the Rutland run on 27th, TC said some people were meeting at the cat and fiddle? Quote Link to comment Share on other sites More sharing options...
