sparkeh9 Posted March 7, 2011 Share Posted March 7, 2011 Can anyone recommend a decent ground anchor (cheaper the better)? I have an inspection pit in my garage that will be filled in with concrete at some point so I can either get a ground anchor that is concreted in or one that you drill holes for.Should ideally fold flat, don't want to be running over a protruding loop, don't think my tyres would appreciate it Quote Link to comment Share on other sites More sharing options...
Guest Posted March 7, 2011 Share Posted March 7, 2011 Torc anchor. Is the only anchor that I know of that is sold secure gold in all categories. Easy to fit too. Quote Link to comment Share on other sites More sharing options...
Rosie Posted March 10, 2011 Share Posted March 10, 2011 how about the second one on here??http://www.elitesecuritysupplies.com/gr ... lt_in.html Quote Link to comment Share on other sites More sharing options...
chiz Posted March 11, 2011 Share Posted March 11, 2011 Your in an ideal position to get a decent anchor put right down into the floor of the garage. Something along the lines of this;http://www.yanchor.com/Once installed, it's completely flush with the floor, there's no attacking that without some pretty hefty tools and lots of noise. Quote Link to comment Share on other sites More sharing options...
techno Posted March 11, 2011 Share Posted March 11, 2011 If you want cheap you can do what a friend of mine did and source some hardened bar an concrete that in, after all it will probably be a chain a thief attacks. Quote Link to comment Share on other sites More sharing options...
Richard Posted March 11, 2011 Share Posted March 11, 2011 If you are having an inspection pit filled in when don't you do as do as Techno suggests but put two hardened bars in then you could do front and back if you so wished. Cost won't be that much higher and what you save of the anchor you can use on a second chain. Quote Link to comment Share on other sites More sharing options...
