Changing/Adjusting Clutch cable problems
Coming out of the end of my road the other day my clutch cable snapped, so I got myself a new one from the breakers, same size etc.
I've took the old one off and put the new one on copying just how it was before yet I can't of done it correctly as I only get a tiny bit of bite when the clutch is nearly fully let out.
I've never done this before so I must be missing something somewhere, i've tried to adjust it up on the clutch itself with the adjusting nut and if I screw it out any further I get nothing, twisted right in as shown on the picture that's where I get a bit of bite, there are some other bolts down below that may need adjusting which i've photographed:
Any tips/advice would be greatly appreciated:
http://i655.photobucket.com/albums/uu271/lee85/DSC04095.jpg
http://i655.photobucket.com/albums/uu271/lee85/DSC04096.jpg
http://i655.photobucket.com/albums/uu271/lee85/DSC04093.jpg
http://i655.photobucket.com/albums/uu271/lee85/DSC04092.jpg
Screw handlebar and clutch end adjusters fully in to give max amount of inner cable showing. Fit nipple to clutch end , remove clutch lever and fit nipple into it. Refit lever to handlebar pivot. Adjust clutch end until most play has gone at clutch lever. Finally adjust at clutch lever until there is. 3mm off free play at lever. The clutch lever should feel tight when pulled to open 3mm gap, then as you pull lever further, the clutch should disengage until fully disengaged with lever touching handlebar.
The only thing I can suggest is check the routing of the cable as it can be pulling the cable tight. Otherwise try a new cable. Venhill make cables for a lot of bikes....as you don't say which bike it's for I can't check if they do one for yours.
No idea what mega just said, might be what i am about to explain, but on your first picture it shows its fully screwed into the handle. It should look more like this (B) http://www.atomiczombie.com/home/brakes/figure-05.jpg
Ignore the letters A and B, I took this off a bicycle site, its actually the brake line of a bicycle, but it works in the same way. I know, i adjusted mine two or three days ago when i changed my handlebars :)
thanks for the advice guys i'll try these tonight after work! brilliant thanks. it's a derbi senda baja 2007 125cc by the way, my work bike!
