i was told to turn the fuel off and run the petrol out of the carbs for storage but it only has on res and prime so i can't turn it off :s
would starting it up once a month stop any fuel in the carbs going off?
Remove vacuum pipe from fuel tap, temporaily block it up with some tape or a small bolt. The tap will have shut due to there being no vacuum to open it and you can run the carbs dry, but it may take a while!
My kwak has no petrol tap, the other bike has one but I never use it, as long as the carbs stay wet you should be ok, its only when the the fuel in the tank evaporates & the carbs dry out you end up with trouble, green fuel leaves deposit as it dries & with the carbs being the lowest point,,, Well, enough said,,,,
others might dispute this method but, it work for me, I've had a bike off the road for 12 months & it started ok but don't forget to keep the battery topped up :wink:
