Raym Posted April 2, 2012 Share Posted April 2, 2012 Hi GuysI have noticed every now and again my off side rear indicator on my Honda cb 750 (2001) is stopping working but the bulb is fine, when i take the bulb out and replace it it works for a while then stops again Any help would be great ThanksRay Quote Link to comment Share on other sites More sharing options...
Bogof Posted April 2, 2012 Share Posted April 2, 2012 Hi GuysI have noticed every now and again my off side rear indicator on my Honda cb 750 (2001) is stopping working but the bulb is fine, when i take the bulb out and replace it it works for a while then stops again Any help would be great ThanksRay Check both the bulb and the holder for corrosion, and check the indicator is securely bolted to the mounting point. Corrosion can be an effective insulator so if there's any present, clean it off. Quote Link to comment Share on other sites More sharing options...
Raym Posted April 5, 2012 Author Share Posted April 5, 2012 Thanks mate will do that this weekend Quote Link to comment Share on other sites More sharing options...
