Guest Posted May 3, 2012 Posted May 3, 2012 hi does anyone know what the live wire colour is on a lexmoto vixen 125 indicator is please. i bouught a indicator buzzer for my bike and the wires on that is black & red but my indicator wires are blue & green.thanks Ant. Quote
Tango Posted May 3, 2012 Posted May 3, 2012 Welcome the the Forum Antony....... You'd need a wiring diagram to be absolutely sure. But one of the wires from the indicators will go to the frame of the bike somewhere (Ground)....so the other one will be the live...... Quote
Colin the Bear Posted May 3, 2012 Posted May 3, 2012 A cheap multimeter can solve so many little problems like this. You should invest. Quote
Roadtorque Posted May 4, 2012 Posted May 4, 2012 At a guess, I would think Black = green & red = blue,,, but don't take my word for it Quote
mattycoops43 Posted May 5, 2012 Posted May 5, 2012 Hi. Don't you need to connect it to the indicator ground? You will have a live for each side so if you connect it to one of those, it will only work when one side is turned on!If unsure about colour, see if one colour has the wire for each indicator joining together locally, there is normally only one earth wire running to the front or rear indicators, then it splits next to the indicators to go to each one, whereas the live will be a separate wire for each light.Hope that makes sense.Matt Quote
