Hi all,
I've bought a cg125 '02 plate and it starts up fine with the kick start ( apart from a few initial choke issues) but my next query is about my battery. The guy who sold me the bike says he replaced the battery 2 years ago with a new one, but the bike has been stationary for the past 3 month albeit on a trickle charge.
My headlights & indicators both work as does the horn & neutral light... But when I push the electric start allI can hear is a quick clicking sound & the engine will not turn over.
Should I look to get a new bat + acid & charger or should I just invest in a charger & have a go myself? Or am I being newbieish and overlooking something else.
Otherwise Im loving the bike!! =cD
Many thanks,
Jon
Battery may be knackered. Give it a boost charge or a long trickle charge with a bike charger and see if it is OK next time you try it. Voltage should be 12.5 to 13.5 volts.
acid batteries, will have charge when brand new... gel ones won't...
that should help you decide about your charge needs.
Once the bike is running it should charge the battery up
It sounds like the battery is not holding a charge so it could be buggered the charging system sounds like its working as the lights and indicators work
Do as mega says and charge it then check it
Save youself some money and just use the kickstart..... :wink: You can use the money you save to buy lots of carrots....you'll need to improve your eyesight for the winter nights as the CG headlight is next to useless...... :lol: :lol:
