Guest Posted August 21, 2012 Posted August 21, 2012 So i swapped the old bulb indicators for some smaller 12 LED micro indicators and now when signalling the blink a lot slower! the turn on for almost two seconds before turning off again compared to the bulbs which was under one second... whats my problem? Quote
mattycoops43 Posted August 21, 2012 Posted August 21, 2012 Well, I think your MAIN problem is that you have taken the proper indicators that look ok off, and substituted some nasty fleabay tat that looks gash and doesn't work properly.But that's just MY opinion! Quote
eastanglianbiker Posted August 21, 2012 Posted August 21, 2012 I guess you're just not magic any more failing that you might need to change the flasher unit to cope with the leds Quote
Adam Posted August 21, 2012 Posted August 21, 2012 Did you put a relay in? If you're changing from the old bulbs to led you will need to put a relay in so the flashing is regular and legal! Quote
pointblank0 Posted August 22, 2012 Posted August 22, 2012 As said above, if you change usual bulbs (around the 5w range), you will need to get a rely that is designed for use with LEDs. The LED indicators draw much less power, so your old relay will not work correctly.Just find out how many pins your old relay has and go on ebay and buy a replacement for LED bulbs.You will need to change front and rear bulbs though, as a combination will cause problems. Quote
Chrissb6 Posted August 22, 2012 Posted August 22, 2012 Hi ya its not a relay you require its a load resistor, have a read on this below hope your soon sorted, its a quick cheap enough fixhttp://reviews.ebay.co.uk/Load-resistor ... 0010344226. Quote
rushwind Posted August 22, 2012 Posted August 22, 2012 yearyaftapurraresistorintoslowthecurrentenoughtomakethel.e.d.sflashatareasonablerate, otherwise they flash a bit like this post Quote
pointblank0 Posted August 23, 2012 Posted August 23, 2012 Hi ya its not a relay you require its a load resistor, have a read on this below hope your soon sorted, its a quick cheap enough fixhttp://reviews.ebay.co.uk/Load-resistor ... 0010344226. Agreed that's a cheap way and effective way of doing it, but changing the relay is much easier and you don't need to bother working out how you're going to hide the resistors on certain bikes. Quote
Chrissb6 Posted August 23, 2012 Posted August 23, 2012 Hi, yes l agree that an electronic flasher unit is a better option, but with so many different types of flasher units available and many Manifacture - model specific l thought that the resistor might be the easier option. Quote
pointblank0 Posted August 24, 2012 Posted August 24, 2012 Yeah, fair enough. I looked into getting LED indicators when one of mine broke, and a replacement for the single light was £16!Quite a few sets on ebay came with the relay for about £15, for all indicators and relay. But I suppose, if you bought the indicators seperate, it may be a bit costy to find a relay on its own. Resistors are very cheap and last longer than your bike will. Quote
