alexanderfoti Posted September 22, 2012 Posted September 22, 2012 Hi allI am trying to replace split handle bar grips on my cb250 superdream 1980.I bought honda oem grips, which have a 22mm diameter, my bars are also 22mm diameter, when fitting the left side, even with grip glue, the grip pulls off way to easily. Any ideas? Quote
oslin06 Posted September 22, 2012 Posted September 22, 2012 Just make sure you are not fitting the twist grip one to the other side it is slightly bigger, if that is ok rap some type around the bar and fit with glue, I use an impact glue when I have to which is not often, the last ones I fitted I had to bash on with a soft hammer.Keith Quote
priest Posted September 22, 2012 Posted September 22, 2012 yeah, it's a good idea to rap smth around Quote
alexanderfoti Posted September 22, 2012 Author Posted September 22, 2012 Have doube checked and they are both the same diameter. This is the second set with this issue. Will wrap some electrical tape around the bars many thanks Quote
mealexme Posted September 25, 2012 Posted September 25, 2012 if you use glue don't use much or you won't get it off again if you ever want to change them. hair spray works apparently Quote
megawatt Posted September 25, 2012 Posted September 25, 2012 Make sure the inside of grips is completely dry and not greasy. I use a smear of silicone for extra grip. Quote
eastanglianbiker Posted September 25, 2012 Posted September 25, 2012 Have doube checked and they are both the same diameter. This is the second set with this issue. Will wrap some electrical tape around the bars many thanksthey should not be the same diameter internally as one goes onto the metal of the handlebar and the other has to fit over the throttle grip so one should be bigger than the other Quote
sliderglider Posted September 25, 2012 Posted September 25, 2012 i spent many years racing mx which meams bending loads of bars lol i used hairspray slips on the dries like glue. Quote
alexanderfoti Posted September 25, 2012 Author Posted September 25, 2012 Have doube checked and they are both the same diameter. This is the second set with this issue. Will wrap some electrical tape around the bars many thanksthey should not be the same diameter internally as one goes onto the metal of the handlebar and the other has to fit over the throttle grip so one should be bigger than the other My thoughts, but even 2 honda oem grips from david silver are the same diameter, a bit of electrical tape and grip glue sorted it though Quote
