Hi, I just bought my son a second hand Suzuki EN-2A 125. It has just had an mot today, and a service, but driving it home this evening we found the throttle was sticking in lower gears and neutral, any easy fix for this?
Could be crap between handlebar and throttle tube. Remove tube, clean it inside, clean handlebar, replace. Could be stiction at carb end. Unscrew top of carb where throttle cable enters, clean carb slide and inside of carb, rebuild. :mrgreen: :mrgreen: :mrgreen:
Also, try loosening the bolt that holds the bar end on. Sometimes the grips slide along slighty and cause friction between the bar ends and the end of the grip rubber.
