Well...there you go mate......got the plan......so just go ahead a do it...... 8-) A good workshop manual will be your bible though mate...... :wink:
Got them all printed off, need to have a rag handy to clean my hands before i flick through them starting to get dirty =p
I had a go at take the right side of the case off today;
http://imageshack.us/a/img20/921/imagewrb.th.jpg
Should've bled it first :P
Also I tried to take this nut off I'm assuming it's the crankshaft seal but it looks bent?
http://imageshack.us/a/img138/4254/imagefno.th.jpg
Is that normal or should I buy new ones?
I use my laptop and have a USB 'workshop mouse' that is filthy greasy. Don't have to touch the laptop that way.
I have a gaming desktop PC so I don't really want that to be left in my garage, appreciate the idea though, the printed off booklet will be fine :)
Its not a good photo but I think you are looking at the lock washer.....you need to tap that down with a hammer and a small chisel so that you can get a socket on it...then when you re tighted it you need to bend it up again. It's to stop the nut coming loose..
Also, when i twist the nut the whole thing turns around is there a tool I can buy to stop this happening?
Just bought;
Dashboard Fairing Panel - Old one cracked when I 'accidently' threw it over in anger :)
Front fairing - Old one cracked, same story
Full Gasket Set - Rebuilding engine
New Battery - Absolutely dead, left ignition on and wont charge :)
New starter motor - Old one screeched when trying to start
And an adjustable pin wrench :)
Should start to see a lot of progress in the next week :)
Yeah i use my Gaming pc for everything :D
Who cares if my mouse gets covered in engine grease :D
But on a serious note, and back on topic..
Your building up a nice list of parts there fella..
Like mine, just as it seams my list is slowly getting smaller, i find more bits i want to buy, and add to the list :D
Haha, it's not as much the grease its more the damp garage as it seems to be colder in the garage than outside :P electricals don't like being damp :D
Yeah, every time I go on ebay there is a new part I need for my bike to make it that little bit smarter but it's only a 50cc and don't particularly want to be spending an absolute fortune on it as much as I'd like too as I have my 125cc bike in 2 months to buy :D
Nipped to halfords and bought a complete set of spanners and other tools to help me with my engine rebuild really don't want to mess it up :D
Only 50 quid a set so not exactly teng tools or snap on but they'll do the job :D
Right well, I took all them cigs out quite easily and quickly but does the flywheel have to be out before I open the crank case?
http://img29.imageshack.us/img29/3742/imageiiiv.jpg
http://img560.imageshack.us/img560/4929/imagejwv.jpg
http://img703.imageshack.us/img703/2093/imageclwc.jpg
Right, can this still be used? :P
Also there's was a lot of debris and rubbish at the bottom of the crankcase I'm also assuming the shouldn't of been there? ;D
Guest Hodgy
I'm sure you could use it as a paperweight, but I certainly wouldn't use it for a piston :? :lol:
Haha, I was being sarcastic, sorry :D
But this bike is smashing up pistons quicker than I can buy them :(
Hi guys not been posting for a while, I've been working all hours working =/ I took all the engine to pieces changed all the gaskets cleaned the debris at the bottom of the crank case etc installed new gaskets, compared the seals on my crankshaft to new ones off the internet and they looked the same, no leakage everything put back together...
Two questions...
If you've seen that picture of my new piston then you'll know it can't be used but I though about putting the very original one back in...
Would this work?
http://imageshack.us/a/img9/9462/imagebwu.jpg
http://imageshack.us/a/img802/5580/imagezwi.jpg
http://imageshack.us/a/img199/1502/imagekoo.jpg
Also what oil do I put in the crankcase and how far do I fill it up?
Guest Hodgy
One thing I've noticed, your new piston broke up around the skirt, and this one has lots of scoring along it, where it's obviously making contact with the cylinder walls, I don't think it should be doing that, have you checked the bearings both in the big end where it connects to the Crankshaft and the gudgeon pin that holds it to the con rod?
Check for any play and/or movement, else you could be back to square one very quickly :thumb:
its a 2 stroke is it not? if it is 2 stroke then u put no oil in crank cases apart from where it gotes around the gearbox but what you should do is lightly coat verything to do with the crank with 2 stroke oil to lubricate it when you are rebuilding it first you need to find out why it is smashing pistons up in 5 mins of being built check play in big end is a good place to start
Hi, I did notice a little play in the crank rod, but it was like 0.4 mm it was very slight :/
I'm absolutely idiotic I never checked them! It's because I'm trying to rush it.. It seems dead obvious to check ah it's all going to have to be took apart again...
Thanks a lot
When I first took the crank case apart I was covered in a black oil would it be gear oil?
I'm going to take it all apart so I'd expect a lot of pictures and questions coming everyone's way soon! :D
Guest Hodgy
Thanks a lot
I think that could be 0.4mm too much, sorry, it looks like you're going to have to pull it apart again and find what's causing the play :thumb:
Nice piston :D
I remember i was racing about in my mates RS turbo a couple of years ago, and bang, valve came into contact with the piston, damn that made a state of the crank casing.. piston and con-rod pushed straight through the side of the block..
And even that piston didnt look as fecked as that one :D
