Josh Posted June 4, 2013 Posted June 4, 2013 Well the subject says it all, i'm looking to get a chain and sprocket set for my xr and I was wondering if somebody would be able to point me in the right direction, i've looked on ebay and there's obviously some very cheap stuff on there which I wouldn't know if I could get away with buying and also i've looked on http://www.wemoto.com/bikes/honda/xr_125_l4_l5/04-05/Also, as a rookie mechanic I know how to fit a chain but is the front and rear sprocket going to be a very simple case of bolts out, sprocket in, bolts back in or is it more technical than that?Thanks! Quote
Josh Posted June 4, 2013 Author Posted June 4, 2013 http://www.ebay.co.uk/itm/Honda-XR125-L ... 1104106523 ??http://www.ebay.co.uk/itm/Honda-XR125-L ... 19d506ac0b ?? Quote
Tiggie Posted June 4, 2013 Posted June 4, 2013 have a look for some videos on youtube, its simple enough to do, though getting the front sprocket off can be an utter pain in the ar$e sometimes Quote
Fozzie Posted June 4, 2013 Posted June 4, 2013 Front sprocket is 2 bolts and a retainer!So unscrew, and move the retainer around a bit so it fits inbetween the splines of the output shaft.Remove sprocketPut new one onPut retainer and bolts back on but do NOT tighten those bolts too much, just as the bolt head nearly touches the sprocket give it half a turn and stop.Rear sprocket is just bolts off, bolts on affairHope that helps Quote
Josh Posted June 4, 2013 Author Posted June 4, 2013 Ah nice thanks I feel confident enough i'll be able to do that no problems then. Does anyone have any input on buying the chain and sprocket set though? Quote
Tiggie Posted June 4, 2013 Posted June 4, 2013 have a look on wemoto, good place to go for bike parts Quote
Josh Posted June 6, 2013 Author Posted June 6, 2013 Ah yeah thanks a lot, I went on wemoto got the chain/sprocket set for £50, just waiting for my paddock stand to come and i'll be attempting the fix. Wish me luck that I manage to realign the rear wheel and brake calipers etc haha. Quote
Lumor_uk Posted June 8, 2013 Posted June 8, 2013 I had a 2006 and was rear drum? piece of piss to do, did mine. I would get some locktite for the bolts. Quote
