Dynamo_Delboy Posted June 15, 2013 Posted June 15, 2013 So, i ha a post on about my bike draining the battery whilst idling.Well today i got it started but the battery drained very quick again.Now, i got told to jump start it in the same way i would a car (car engine running) done that and now the bike won't start at all, getting lights on but when trying to start the bike there is nothing at all, not even the ticking sound when pushing the starter..Checked online and seeing loads of posts about how you shouldnt do it with car engine running So question is, what have i killed on the bike (Cbr600 f2)Actually raging at my banger of a pal for saying to do it as you would a car Quote
Stu Posted June 15, 2013 Posted June 15, 2013 your not supposed to do it with the engine running as the amount of amps a car charging system puts out is too much for the battery and can kill it remove the battery and charge it and see if it holds a charge also check the voltage of the battery it may have enough to put the lights on but thats it Quote
Dynamo_Delboy Posted June 15, 2013 Author Posted June 15, 2013 Thanks mate, gonna go and buy a proper motorcycle battery charger and see how it goes.Won't make that mistake again Quote
Stu Posted June 15, 2013 Posted June 15, 2013 bikes are fine to jump off a car without them running though get yourself a bike charger and a multimeter while your at it charge battery then leave for an hour before checking voltage the closer to 13 the better Quote
Dynamo_Delboy Posted June 15, 2013 Author Posted June 15, 2013 bikes are fine to jump off a car without them running though get yourself a bike charger and a multimeter while your at it charge battery then leave for an hour before checking voltage the closer to 13 the better Will do mate, long does it take to charge the battery? Quote
Stu Posted June 15, 2013 Posted June 15, 2013 depends on the charger and the size of the battery to be honest Quote
Tango Posted June 15, 2013 Posted June 15, 2013 Charged overnight should be OK.........but, as Stu says, it depends on the charger, size of battery and how much charge is left in it to start with...... Quote
Dynamo_Delboy Posted June 15, 2013 Author Posted June 15, 2013 Cheers guys.Ill let ye know how i get on lol Quote
MacLean Posted June 17, 2013 Posted June 17, 2013 Just another thing to check, make sure in all the faffing about you haven't flicked the engine cutoff switch. The fact that lights are on but your getting absolutly nothing from starter button sounds like engine swtich may have been flicked...Good luck if not though. Quote
Dynamo_Delboy Posted June 18, 2013 Author Posted June 18, 2013 Quick question, will a regulator/rectifier from an sv650 fit the cbr600?Guy in the work has a spare and said i can have it if it works. Quote
Stu Posted June 18, 2013 Posted June 18, 2013 you can get any reg/rec to work if you know what you are doing and are prepared to mess about with wiring (it is really simple) if your not wanting to mess with wiring then get one that fits but first check things out with a multimeter otherwise you could be replacing bit that are ok Quote
Dynamo_Delboy Posted July 18, 2013 Author Posted July 18, 2013 So, having being on holiday, work and other things i havent had a chance to do anything with the bike until last night.Goes to take it to my bro in laws to get the multimeter and bike dies at the lights, no battery life left.Gets another fully charged battery brought out to me to get me back home.Goes down tonight and battery is totally drained.Put a new battery in it and the rectifier starts to smoke and melt (without having the bike switched on) plug also meting and connectors in it are totally black and gooie.Obviously the rectifier/regulator is knacked but why has it drained the battery overnight?Ive have no alarm or anything to drain power from it.Is this just part of the problem.Will upload pics of rec/reg and plug soon Quote
Dynamo_Delboy Posted July 18, 2013 Author Posted July 18, 2013 http://s12.postimg.org/w2zd13gqx/image.jpghttp://s12.postimg.org/cjurrqhzd/image.jpghttp://s12.postimg.org/yghas3v61/image.jpghttp://s12.postimg.org/p7f4hzma1/image.jpghttp://s12.postimg.org/aa6ngz91l/image.jpg Quote
Tango Posted July 18, 2013 Posted July 18, 2013 The reg/rec is connected to the battery......if the reg/rec develops a problem it could drain the battery....and in your case....go up in smoke..... Deffo need the reg/rec replacing......and hope that the pins in the connector are not too cooked.....as they will not be so easy to replace..... Quote
Dynamo_Delboy Posted July 18, 2013 Author Posted July 18, 2013 Cheers mate.£159 + vat for it Aw well needs must Quote
Tango Posted July 18, 2013 Posted July 18, 2013 Cheers mate.£159 + vat for it Aw well needs must Maybe a bit cheaper mate:http://www.electrexworld.co.uk/cgi-bin/ ... PR=-1&TB=A Quote
Tango Posted July 18, 2013 Posted July 18, 2013 Is this the one specifically?.......looks like it comes with a new plug and pins....just need a crimper to replace the old pins?http://www.electrexworld.co.uk/cgi-bin/ ... RR58#aRR58 Quote
Dynamo_Delboy Posted July 18, 2013 Author Posted July 18, 2013 Need to check when i get in mate.Using my phone and its not showing any pics Quote
Dynamo_Delboy Posted July 18, 2013 Author Posted July 18, 2013 not the exact same mate however I reckon it will fit and the plug is also the same.might just be made slightly different since '92 could be just the one im looking for Quote
Chrissb6 Posted July 18, 2013 Posted July 18, 2013 (edited) Hi,If your not sure in what your doing better to get a pro to check and fit it.There may be another reason why the regulator has gone up in smoke. You don't want to fit another one at £159 + vat and watch that go up in smoke as well! You need to know the reason its happened in the first place before you go ordering new parts. There could be a short or a trapped wire, get it checked over first. Edited July 19, 2013 by Chrissb6 Quote
Matt Strange Posted July 19, 2013 Posted July 19, 2013 The three yellow wires are from the stator. With ignition off, Each should be tested to make sure they are not shorted to ground, and then in turn to each other i.e. yellow wire to each other yellow wire, the resistance should be about 0.1-0.3 ohms. The green wire is for the regulator earth, the red is the 'charging wire' to the battery. With the ignition off again, check the green earth wire by putting the positive probe of a multimeter on the battery + and then probe the green wire with the negative m.m. probe, you should be within 0.3v of battery voltage. Any lower ( i.e. battery voltage is 12.6v and you're getting only 12.2v) and you'll have high resistance in the wire or the connections are dirty. No voltage = open circuit, the wire has become disconnected.The red wire should read battery voltage within 0.3v. Again, if that's not the case then it's the wire or connections at fault.* the 2 paragraphs above, I presume you have a good battery. Quote
eastanglianbiker Posted July 22, 2013 Posted July 22, 2013 i think littlecat has a spare reg/rec for an r6 if they are the same or at least she did have might be worth giving her a shout and asking Quote
Dynamo_Delboy Posted July 26, 2013 Author Posted July 26, 2013 Just check there and it says its also compatable with Yamaha SR500, TDM850 (2000 on), YZR1000 (R1) 03 on. Nothing sbout the r6 though Quote
Dynamo_Delboy Posted July 26, 2013 Author Posted July 26, 2013 Just googled it there and found this so it might work with a r6 unit.[in the future if you don't want to fry voltage Rectifier/regulators buy a Yamaha R6 or R1 unit off of ebay, they are larger and work better without frying. Or buy a "honda" aftermarket version with a heat sink built onto it. The R1 or R6 unit ( 5 wires ) is the best choice.] Quote
Dynamo_Delboy Posted July 26, 2013 Author Posted July 26, 2013 Alot of people saying that pre 2005 r6 models are 5 pin r/r like the cbr. So might say to littlecat and see what year hers is. Quote
