I bought a new fuel pump for my ybr 125 and proceeded to remove the old assembly from inside the tank. All went well until I tried to remove the cage surrounding the old pump!
There are 3 clips (see attached pic) I cannot get these to budge and am wary about prizing out the cage as it's plastic and may crack?
Can anyone who has changed one of these before give me the best plan of attack before I go crazy...!!!
Many thanks, Dave.
That clip that you have ringed should push in allowing the cage to slide past...
That's what I would have thought but it's solid and won't budge...! not even a smidgen.
I fear it will snap if I get too brutal, but I suppose I don't have any choice really... :?
Try a small flat headed screw driver under the lip of the clip as far as you can get it in then lift it up and with a bit of luck it should move! You might need to jam something in each one to keep them held back whilst you do the next one.
Good luck!
  • 1 month later...
Tried for 2 months to do it and in the end sent it to the shop. The mechanic almost committed suicide doing it but now it is done.
I pity anyone else having to do this.
As the mechanic said...What a fekkin stupid design.
tbh, i didn't think the fuel pump on a YBR was much of a consumable part. I stayed away from mine!
It was the problem that's for sure. Bought one off fleabay for £29.
Just annoyed I couldn't save on fitting charges.
  • 7 months later...
