Rik398 Posted September 24, 2013 Share Posted September 24, 2013 Hey folks.So its finally got to the point where I can no longer try and defend my chain - its buggered and idealy needs replaced.So, I got an 8 ring chain and sprocked set. It says it comes with soft rivet link, and is for my bike. So, I am guessing I will need a link remover in case it is too long, but do I need a tool to connect it ir is there like a special link with a lock? Cheers folks. Quote Link to comment Share on other sites More sharing options...
Bogof Posted September 24, 2013 Share Posted September 24, 2013 So, I am guessing I will need a link remover in case it is too long, but do I need a tool to connect it ir is there like a special link with a lock? Cheers folks. You need a tool and... Quote Link to comment Share on other sites More sharing options...
Rik398 Posted September 24, 2013 Author Share Posted September 24, 2013 Sound as a pound. Got a breaker / rivet tool and will use a file instead of a dremel, I think a dremel is handy if you are going to use it for other things as well but will probably not buy one for this one job. Looks fairly straight forward, just needed to know the right tool lol. Thanks for the help Quote Link to comment Share on other sites More sharing options...
