Chrome.
Information provided by Gary...
You don't polish chrome, you clean it. Unlike aluminum and stainless, chrome don't oxidize much, it's pretty inert, very hard, and usually
pretty thin. I have tried a bunch of polishes, including the expensive German ones, and have found nothing that will remove scratches from
chrome. You live with a scratch in chrome, or replace the part.
If you are real careful not to scratch it, all you have to do is remove the schmutz and the shiny chrome will be (somewhere) underneath.
Use soaps and solvents, but keep abrasives far away from chrome. Be very careful to use clean, soft rags, one imbedded metal chip will
ruin your day.
Aluminum and stainless
There are hundreds of alloys of both, but all share the fact that they oxidize at the surface. In fact, that oxide layer is what protects
the metal from further corrosion. All you have to do is remove the oxide, and get it smooth enough (easier said than done), and it will
rival chrome in shine.
Smoothing
If the part is just oxidized and gray, but smooth, skip on down to "Buffing." But if it is pitted or scratched, it must be smoothed. Ya
can't polish pits. Trust me in this.
Wet-sand the part with #600 wet-dry paper using a little liquid dish soap in the water. Sand for a while, then wipe off the dreck, and
look closely. If you can still see the pits or scratches through the dark, dull gray, ya ain't done. When you have a uniform, dull gray,
you're ready to buff. Don't worry too much about screw recesses and other hard to reach places, they don't show in the finished job if the
edges are smooth.
Buffing
The final polish on metal is achieved by buffing it with a rotating wheel which has been loaded with a buffing compound. These compounds
are very fine abrasives, usually combined with wax in a bar form. From the coarsest to the finest, they are:
Emery (gray) - aggressive, usually used on steel.
Tripoli (brown) - usually used on brass.
White compound (white) - for fine polishing.
Jeweler's Rouge (usually pink) - the finest, for a mirror finish.
I usually don't use any except emery and rouge. Emery is good for a first cut on stainless, or on aluminum where I didn't sand enough,
followed by rouge. Usually you can go directly from wet sanding to rouge.
Buffing is a "feel" thing. Keep the wheel moving and you will see when it is polishing effectively. Wipe off the wax now and then and
have a look. Different alloys require different compounds, speeds, and pressure. You can't really hurt anything, so experiment.
If you want to get really ott, do a final hand polish (see "Maintenance" below).
Wheels
Use only cloth wheels. Sisal is too aggressive (ok for heavily pitted alloy), and felt doesn't conform to the odd shapes of bike parts.
Look at the side of a buffing wheel and note the ring(s) of stitching. Fewer rings means softer (for polishing), more rings means harder
(for cutting). A 6" wheel can have from one to seven rings. Use a harder buff with emery, a softer buff with rouge. Speed depends on wheel
size. For a 6" max. 3500 RPM, 4" about 6000 RPM, 2" about 12000 RPM, and the little sub-1" wheels can be turned up to 15000 RPM. Go by the
wheel manufacturer's specifications.
Wheels come with a bunch of different hole sizes, so get the right mandrel or bushings. An unbalanced wheel at 6000 RPM will get your
attention! The mandrel is the Steel shaft which holds the wheel, and is turned by the tool. You can get sets for use in an electric drill
at the hardware store, but you need a drill that turns up to about 2000 RPM.
Start at slower speeds, and work up. You can be too fast as well as too slow.
Use the buff so that it rotates off the edge of the piece. If it rotates toward the edge, well, let's just say you will learn quickly after it throws a couple of pieces at you.
Load the wheel by arranging it so the top is turning away from you, then apply the bar of compound for a few seconds. You will see it melt
in. After you load a few times, you will see clumps of compound build up in the wheel. Again, have the top of the wheel turning away from
you while you"rake" the wheel. They sell wheel rakes, but I just use an old hacksaw blade. Rake between different compounds, too, but it's
best to have one wheel dedicated to one compound. Mark the wheel with a magic marker. WEAR EYE PROTECTION! Read that last sentence again.
Tools
Electric drill turning 2" and 4" wheels at about 2000 RPM. I use a Bosch, which was the fastest I could find, and it does a nice job with
hardware store wheels. The problem is, those wheels won't fit into all the little spaces. By and large, use the biggest wheel that will fit, as the smaller ones can streak.
"Dremel" type tool, use the low or middle speeds (12000, 24000). The 1" buffs will fit most places, and there are small (3/8) felt bullet
shapes which fit into screw recesses.
Bench mount grinder with two 1/2" buffs on each shaft, a hard pair for emery, soft for rouge. This is wonderful if you can take the part
to the buffer.
Sources
English Custom Polish http://www.englishcustompolishing.com/eneu/index.html
The finest hand polishes in the world
Frosts auto restoration. http://www.frost.co.uk/productList.asp?catID=27
Good range of polishing kits,small bobs and spare polishes.
Spit & Polish http://stores.ebay.co.uk/SPIT-AND-POLIS ... eZl2QQtZkm
ebay seller with a large range of mops and kits etc
Perfect Polishing kits http://www.perfectpolishingkits.co.uk
Well known supplier of polishing kits etc.
The polishing shop http://www.thepolishingshop.co.uk
Ran by one of the founders of cetem polishing supplies good range of supplies and help guides.
Busters and M&P also sell kits but arent as specialised as above.
Machine Mart http://www.machinemart.co.uk/search.asp?q=bench
Bench grinders
Abbey power tools http://www.abbeypowertools.co.uk/subpro ... 0817.aspx0
Bench grinders and stands
Maintenance
As I mentioned above, the oxide protects the metal, so as soon as you are finished polishing, the metal starts to oxidize again. I haven't
found anything really good to protect it.
Waxes tend to "gray" the sheen, and don't last long in any case.
About once a month I do the following, which takes about 60 minutes for the entire bike. Use the Showman’s Ultra Fine Polish you got from
English custom polishing above. It is very fine custom metal polish and produces excellent results without scratching. Shake Hell out of
the bottle, upside down (careful!),add a small quantity onto a cloth such as cotton or a old t-shirt etc but make sure it is clean apply
to the alloy.
Polish by hand, rubbing in a circular pattern as much as possible, until the area turns black. Allow to dry and buff off with another
perfectly clean rag. If you drop the rag, throw it away and start another.
So far this seems to be all that is required to keep the polish bright.
