Gazza7682 Posted January 26, 2014 Posted January 26, 2014 http://img.tapatalk.com/d/14/01/27/yne7e2a5.jpghttp://img.tapatalk.com/d/14/01/27/e6yzury8.jpghttp://img.tapatalk.com/d/14/01/27/ehy8u5en.jpgAs you can see not much was done here apart from pannels were taken off and a few small bits stripped Quote
Mr Fro Posted January 26, 2014 Posted January 26, 2014 You have many pink things in your garage! Looking forward to seeing what you do. Quote
Gazza7682 Posted January 26, 2014 Author Posted January 26, 2014 http://img.tapatalk.com/d/14/01/27/tanuge4a.jpghttp://img.tapatalk.com/d/14/01/27/atedameb.jpghttp://img.tapatalk.com/d/14/01/27/ugene9e6.jpgHere some more work done after today. Stripped quite alot including all cables, rear mudguard, handlebar with all components, tank, seat etc... Now need to get a centre stand which is hard to find on the cheap so I can take engine off, wheels, forks and suspensions (unless anyone has ideas for alternative things to get the bike to be jacked). After dismanteling the hard graft starts I will be cleaning engine and respraying black also will be sanding down the frame and respraying this. Then to put everything back together with new and existing parts. Quote
eastanglianbiker Posted January 26, 2014 Posted January 26, 2014 rope around the roof rafters after all no weight left in the frame once engine is out of it Quote
Tango Posted January 26, 2014 Posted January 26, 2014 Or a couple of blocks of wood under the rider footpegs (as long as they're not folding ones)..... Quote
Gazza7682 Posted January 26, 2014 Author Posted January 26, 2014 Or a couple of blocks of wood under the rider footpegs (as long as they're not folding ones)..... Very good idea. Will try it. Do you think I can get the engine out when its on the side stand? Quote
eastanglianbiker Posted January 27, 2014 Posted January 27, 2014 yes that engine will come out with bike on side stand 2 bolts at the back one or two at the front and maybe on at the top then wriggle it out Quote
