Glorian Posted March 3, 2014 Share Posted March 3, 2014 Right before i start, 2 weeks ago, i cleaned lubedand tightened my chain, wasn't to loose wasn't to tight it was just right (Like the porridge) all fine, been riding it to work every day for 2 weeks, now yesterday i pop to shops to get a new rear bulb as my light (not brake) one has blown, get 2 minutes from the shop and i hear a GOD AWFUL noise. notice i have no power, but engine is still going, so i pop to the side of the road, kick stand down, and inspect, my chain is off the sprocket, no problem i think. I also notice my chain guard (Top only) is snapped at the back and the metal piece that holds it in place has bent (God knows why?) i think that this has snapped off, pushed into the sprocket which has caused the chain to miss the sprokcet and slip off sound plausible? I kept the broken parts as i'm going to a local sinnis garage tonight see what they say (also going to quiz them on why water has gotten into the rear brake light?) Thankfully i managed to get the chain back on the sprokcet rather easily looped some chain on the top, and walked the bike backwards slowly and it went back on. but now i'm riding without it's guard. Is this safe for the chain? It only covered the top half of the chain anyway. Quote Link to comment Share on other sites More sharing options...
Joeman Posted March 3, 2014 Share Posted March 3, 2014 Doesn't sound much fun!But if you can get your chain back on by just looping it over the sprocket and rolling the bike, its probably too loose.Chain guard is there to stop oil splatter, so you're OK riding without it. Quote Link to comment Share on other sites More sharing options...
Glorian Posted March 3, 2014 Author Share Posted March 3, 2014 could only loop about 5-6 sprockets, but might tighten it up a little just to be safe, going to garage on way home so will ask mechanic if it's to loose, doesn't feel it has a little movement in it. Quote Link to comment Share on other sites More sharing options...
Adam Posted March 3, 2014 Share Posted March 3, 2014 Oh dear the same happened to me but I hadn't touched the chain and it was definitely too lose. Try pulling the chain off the sprocket at the back it shouldn't come off (much). Is your chain new? Quote Link to comment Share on other sites More sharing options...
OhJay Posted March 3, 2014 Share Posted March 3, 2014 Is the chain consistent all the way round? Did you happen to adjust it to an incredibly tight spot and that made it far too loose somewhere else? Quote Link to comment Share on other sites More sharing options...
Glorian Posted March 3, 2014 Author Share Posted March 3, 2014 If i'm correct it adjusts by moving the wheel backwards slightly, can upload pics later to make it clearer =D but yeah new chain and will have a look how much (if any dont think it does)it comes off the sprocket. Quote Link to comment Share on other sites More sharing options...
Stu Posted March 3, 2014 Share Posted March 3, 2014 Sounds shafted to me I would replace chain and sprockets ASAP Quote Link to comment Share on other sites More sharing options...
littlecat Posted March 3, 2014 Share Posted March 3, 2014 Quote Link to comment Share on other sites More sharing options...
Tango Posted March 3, 2014 Share Posted March 3, 2014 If it's a new chain it could have stretched a bit as some new chains do.....and was then so loose it jumped the sprocket.......check the tension again...... Quote Link to comment Share on other sites More sharing options...
Adam Posted March 3, 2014 Share Posted March 3, 2014 As tango said a new chain will stretch so the chances are it's not tensioned enough. It's all part of the learning curve, I don't know much about bikes but like you I'm picking things up and just fixing bits and pieces when I need too. Quote Link to comment Share on other sites More sharing options...
Glorian Posted March 4, 2014 Author Share Posted March 4, 2014 Checked it again it is quite loose (even after being tightened 2 weeks ago) So i will tighten it tonight, took car today shame as it's nice weather Quote Link to comment Share on other sites More sharing options...
Adam Posted March 4, 2014 Share Posted March 4, 2014 New chains stretch under the strain so keep an eye on it best thing to do is just lift it up with your boot before every ride you'll get an idea of how much play it should have in time. Quote Link to comment Share on other sites More sharing options...
klingelton Posted March 4, 2014 Share Posted March 4, 2014 doesn't pain to check chain tension once a week when you're lubing everything. If you're an all year rider, you should be giving everything a once over once a week anyway. have your gear changes been snatchy and loud this last week or so? Quote Link to comment Share on other sites More sharing options...
Glorian Posted March 4, 2014 Author Share Posted March 4, 2014 Only first it sometimes clunks when i'm changing down. I usually lube/clean/check bike over once a month and give it a quick once over 2 weeks inbetween. i'd say i only do about 100miles a week unless i go out on the weekend. Quote Link to comment Share on other sites More sharing options...
Adam Posted March 4, 2014 Share Posted March 4, 2014 The clunking will be down to the chain tension, once you've tensioned it properly your gear changes will be much smoother and the bike will feel better. Quote Link to comment Share on other sites More sharing options...
