Guest Posted March 24, 2014 Posted March 24, 2014 Hi All...I have an issue with my Sinnis Eagle headlights...they won't stay on dipped beam at all but will stay on on full beam with revs if revs drop then they go off as well...side lights work fine....any ideas anyone....all ideas welcome. Quote
Tango Posted March 24, 2014 Posted March 24, 2014 Check the battery voltage.....and also the connections to the headlamp in case you've got a high resistance connection. Dunno if the lights on that bike are relay controlled....but if they are I'd be looking at that too..... Quote
Guest Posted March 24, 2014 Posted March 24, 2014 Thanks for that....will have a fiddle at the front end. Quote
Tango Posted March 24, 2014 Posted March 24, 2014 Thanks for that....will have a fiddle at the front end.Have a look at the bike when you get time too..... Quote
Guest Posted March 25, 2014 Posted March 25, 2014 Hi...had a fiddle then went onto bike....oooh eerrrcan't get my head round it....when I turn ignition on,I have no power to the bike...no lights,horn ,electric start etcit will kick first time,then I have power....stuck the meter on the battery and it said 12.7.....any ideas anyone....?? Quote
Guest Posted April 1, 2014 Posted April 1, 2014 Main fuse it was.....just one issue to sort,I have no indicators at all....do these bikes have a relay...?? Quote
