Guest Posted October 6, 2014 Share Posted October 6, 2014 On my Kymco Pulsar 125, when the engine is running(Kick-start) all the lights(dash, indicators, brake etc) do not work and neither does the horn or electric start.I have changed my fuses and charged my battery but still no luck.I was wondering if anyone could help me with a solution Quote Link to comment Share on other sites More sharing options...
Adam Posted October 6, 2014 Share Posted October 6, 2014 First thing that comes to mind would be fuses but you've changed them already.. Have you checked the connections to the battery to make sure they're tight and not corroded? Grab a multimeter and check the voltage of the battery, it should read over 13v when the bike is off. Quote Link to comment Share on other sites More sharing options...
Guest Posted October 6, 2014 Share Posted October 6, 2014 First thing that comes to mind would be fuses but you've changed them already.. Have you checked the connections to the battery to make sure they're tight and not corroded? Grab a multimeter and check the voltage of the battery, it should read over 13v when the bike is off. Okay, I will check the connections and voltage when I get the chance tonight or tomorrow and I'll let you know Quote Link to comment Share on other sites More sharing options...
eastanglianbiker Posted October 6, 2014 Share Posted October 6, 2014 the battery should read 12volts when engine off and been sitting while then start it up and you are looking for about 12.8-13 then at 3000 rpm looking for about 13.5 but no more than 16 that could mean reg/rectifier probs if going to high Quote Link to comment Share on other sites More sharing options...
Guest Posted October 7, 2014 Share Posted October 7, 2014 I done the voltages and they were fine and then figured I got a loose wire somewhere because after a little play around with wires it all works again, thank you for the help though just need to wait for them to go off again to locate the loose wire. Quote Link to comment Share on other sites More sharing options...
