Harri Posted December 11, 2014 Posted December 11, 2014 Hi all, well I've picked up a bike. A Suzuki XF650 with the unfortunate model name 'Freewind' Just over 19000 on the clock and it's a bike I'm very happy with BUT. When I picked it up the neutral light wasn't working. The seller said he hadn't noticed and it must have just gone. So I'm thinking no more than a bulb change. Then I read this :http://www.ludd.luth.se/~joshua/xf650/xf650.htmlhttp://www.kiwibiker.co.nz/forums/showt ... light-woeshttp://dr650.wikia.com/wiki/Potential_p ... e_aware_ofI'm in the process of removing a load of fairings as it seems the only way of getting at the consul holding the bulbs. When I eventually find a 12V 1.7W bulb that is! (Not at Halfords or car spare shop.) I'm guessing as I go along. The digital manual photos are total crap and a waste of space!Check out the links and tell me what you think - change the bulb - no change - get the cover off? Would you ride it in the meantime?Barcud Quote
cockercas Posted December 11, 2014 Posted December 11, 2014 Dose it select netral fine? I dont ever trust the light. I always put it in N then slowly release the clutch. Quote
Harri Posted December 11, 2014 Author Posted December 11, 2014 Hi, yes it selects neutral fine and I can feel the neutral.Barcud Quote
GazzyG Posted December 11, 2014 Posted December 11, 2014 Any bike shop should have 1.7w bulbs.Also, it could be the neutral switch rather than the bulb. Quote
Tango Posted December 11, 2014 Posted December 11, 2014 Looking at the links I think I'd be inclined to remove the clutch cover and inspect the Neutral light switch......just incase..... Quote
Harri Posted December 11, 2014 Author Posted December 11, 2014 So I need to source a clutch cover gasket first. And not ride the bike until then? p.s. are pattern gaskets as good as genuine?Barcud Quote
Stu Posted December 11, 2014 Posted December 11, 2014 moved to the right section without reading the links I can tell you your problem if its not a bulb or wiring! the pick ups very rarely go wrong probably one in a million!! if the bulb and wiring check out fine then you need to remove the gear position sensor place it on top of a sheet of sandpaper on a flat surface with the contacts facing the sandpaper then sand the sensor flat then remove the pin and sand the end of it they end up with a fine film on them over time and it stops the contacts working pretty common problem on suzuki's if the bike has fuel injection you will want to sort this out asap as the bike may not be running the correct fuel mapbut you can check the voltage at the connectors to see if it changes when shifting through the gears to verify that it is actually working as it could just be neutral thats not been picked up which isnt a big problem Quote
Harri Posted December 11, 2014 Author Posted December 11, 2014 Okay stu, I should have posted in pitstop.Is it a bulb change first then do you think?And then a clutch cover removal?Not sure what this means Stu - but you can check the voltage at the connectors to see if it changes when shifting through the gears to verify that it is actually working as it could just be neutral thats not been picked up which isnt a big problemBarcud Quote
Stu Posted December 11, 2014 Posted December 11, 2014 well if its carbed as above I would probably just live with it rather then pull the clutch cover and sensor as it can be a ball ache yeah swap the bulb first as for checking the voltage you need to find where the sensor joins to the wiring loom and measure the voltage as you go through the gears with the bike ignition on......it doesnt need to be running although with it not been injected it may not alter the voltage! ........the voltage is altered to tell the ECU what gear it is in as some injected bikes have different fuel maps and retarded ignition in lower gears Quote
Harri Posted December 11, 2014 Author Posted December 11, 2014 I'll try my local bike shop for a bulb tomorrow and take it from there. That's if I can get to it cheers all. Quote
eastanglianbiker Posted December 12, 2014 Posted December 12, 2014 reading the first link is the bike cutting out as you put the side stand down with clutch in?if so its not the bulb try what the links suggest before pulling fairings and engine casings off just to make sure could save you money Quote
Harri Posted December 12, 2014 Author Posted December 12, 2014 Okay, I only have half the fairings off. I started the engine, held in the clutch, let down the side stand, and the engine .............. stayed running So, that would point to a bulb failure or wiring problem ? Wotcha think ?Barcud Quote
Stu Posted December 12, 2014 Posted December 12, 2014 yup sounds like it to me! bulbs are cheap enough to replace although wiring is free to checkwhich one you do first is up to youyou could always pull the bulb and stick a few bits of wire on it and connect to the battery to see if it works Quote
eastanglianbiker Posted December 12, 2014 Posted December 12, 2014 yep bulb sounds like its gone now you are halfway into it finish the job and pull it out put new one in and before refitting it all turn ign on to see if it work Quote
