Yup it will be fine as will all other coolants out there
You will need more than 1 litre though!
Thanks stu, it's only for a top up at the moment, going to use engine ice next time i do a full flush
I wouldnt use it for top up unless you know whats already in the system
if you mix them they can turn to jelly and block waterways
forget engine ice its not worth the extra
billions of people have no trouble with normal coolant so why the need for engine ice I will never know!
I don't not flushed the coolant since i bought the bike in march, so you recommend a full flush then stick with prestone
Yes a full flush and use any coolant that meets the specs
I use some from euro car parts called triple QX £17 for 5 litres of concentrate this will probably do at least 3 changes
also use de ionised water its cheap enough and stops any corrosion and lime
de ionised water is cheap £3 or so for 5 litres from halfords usually called battery top up water
if you dont know whats in the bike I would flush 2 or 3 times with water then add your 50/50 coolant mix
Great thanks Stu, I will do a thorough flush and refill with prestone and just stick to using that
Just watched a youtube tutorial on flushing your radiator which says on first flush use 50/50 mix of water and vinegar ? is this necessary or will water alone suffice.
oh and remember when flushing to fill the system and run it around in the engine to mix the coolant thats still left in this ensures its diluted as much as possible
dont boil it until it warms the radiator up will suffice that way you know your stat has opened
yup clean deionised water for every flush
some people go to the extremes of flushing the last one with 50/50 coolant
once you have done this every coolant change you do from then on can just be a straight change and no flushing
you are just making sure the old stuff is out as you dont know whats been put in in the past
best to be safe than sorry
drain the fluid through the drain bolt then replace the drain bolt
fill up with water/flush
replace rad cap run up to temp leave to cool for a bit
drain through drain bolt flush again repeating the steps above
water alone will be fine
remember not tap water! it has too much limescale in it
I'm planning on doing a coolant change next week, and reading through the haynes manual, it just says use a hose for the water, ie normal tap water
That's up to you but I wouldn't
Just because Haynes says it it doesn't mean it's right ;-)
