min200 Posted January 29, 2015 Posted January 29, 2015 Knowing some of you good folks on here are good at this computer stuff I thought it the best place to ask about PDF software.Are there any good free PDF software packages that anyone uses? I want to put a PDF file together but once I typed it into google and say the billions of confusing results I walked away thinking best to ask someone who knows better than me So any recommendations please folks? Quote
donald463 Posted January 29, 2015 Posted January 29, 2015 If you have Microsoft Word or Publisher 2007 or later there is a free file extension that allows you to save as a PDF document. Quote
Joeman Posted January 29, 2015 Posted January 29, 2015 I used to use CutePDF.http://www.cutepdf.com Quote
Guest Posted January 29, 2015 Posted January 29, 2015 I used to use CutePDF.http://www.cutepdf.comMe too. Great programme. Quote
Grumpy Old Git Posted January 29, 2015 Posted January 29, 2015 Also Adobe have a PDF reader which is free to download. Quote
soll Posted January 29, 2015 Posted January 29, 2015 cutepdf works well use word to create your documents then print as pdf file.... works a treat.means you can alter with word and just print as ness. Quote
Bogof Posted January 29, 2015 Posted January 29, 2015 OpenOffice - www.openoffice.org By default it enables you to export as pdf. And it enables you to avoid Microsoft which is always a bonus. Quote
min200 Posted January 29, 2015 Author Posted January 29, 2015 Now you see this is one of the many reasons I love you guys! Thanks folks Quote
RantMachine Posted January 30, 2015 Posted January 30, 2015 Adobe InDesign CC, free one month trial Quote
XmisterIS Posted January 30, 2015 Posted January 30, 2015 Personally, as a software engineer, I recommend Bullzip PDF Printer. It really is all you need. You install it and then you can print anything you want to it as if it were a printer - but it saves the output as a PDF document. No bells, no whistles, just a plain, simple, bulletproof piece of software. It's free and I've been using it for years. Why choose anything else which has unnecessary complication that comes at a cost?See here: http://www.bullzip.com/ Quote
jamesd1981 Posted January 30, 2015 Posted January 30, 2015 I use foxit pdf reader - http://www.foxitsoftware.com/Secure_PDF_Reader/ and Debenu pdf for more complex editing - http://www.debenu.com/products/desktop/ ... pdf-tools/ Quote
min200 Posted January 30, 2015 Author Posted January 30, 2015 Thanks again everyone I will be back with more questions on how to use the software soon lol Quote
RantMachine Posted February 1, 2015 Posted February 1, 2015 Personally, as a software engineer, I recommend Bullzip PDF Printer. It really is all you need. You install it and then you can print anything you want to it as if it were a printer - but it saves the output as a PDF document. No bells, no whistles, just a plain, simple, bulletproof piece of software. It's free and I've been using it for years. Why choose anything else which has unnecessary complication that comes at a cost?See here: http://www.bullzip.com/ Depends what you're doing! My work would look shite if I made it in Paint or Word then used a print-as-pdf tool Quote
XmisterIS Posted February 2, 2015 Posted February 2, 2015 Personally, as a software engineer, I recommend Bullzip PDF Printer. It really is all you need. You install it and then you can print anything you want to it as if it were a printer - but it saves the output as a PDF document. No bells, no whistles, just a plain, simple, bulletproof piece of software. It's free and I've been using it for years. Why choose anything else which has unnecessary complication that comes at a cost?See here: http://www.bullzip.com/ Depends what you're doing! My work would look shite if I made it in Paint or Word then used a print-as-pdf tool Surely that depends on how you send it to the tool? E.g. making sure that the resolution is preserved (300 or 600 dpi for print quality, I am guessing), and the colour algorithms are correctly set up (e.g. using CMYK instead of RGB for printable material). Seems to work for me!I like bullzip because you can modify the kernel client layer of the tool as you wish via an INI file, if you use the Linux distro. Quote
RantMachine Posted February 2, 2015 Posted February 2, 2015 I just meant the initial creation of it more than the output settings. Vector graphics, linked object, bleed and trim, quality of text rendering and feathering, to follow your theme of output colour there's always Pantone support to consider, etc, etc.That being said, even on the output settings front you'll find that software designed for the purpose of PDF creation gives a lot more output options than standard print dialogues paired with a "print as PDF" tool. Quote
XmisterIS Posted February 2, 2015 Posted February 2, 2015 I just meant the initial creation of it more than the output settings. Vector graphics, linked object, bleed and trim, quality of text rendering and feathering, to follow your theme of output colour there's always Pantone support to consider, etc, etc.That being said, even on the output settings front you'll find that software designed for the purpose of PDF creation gives a lot more output options than standard print dialogues paired with a "print as PDF" tool. Sounds like you do more advanced printmaking than me! I just use Adobe Photoshop to design web graphics, and the PDF printer to print technical manuals and product brochures! Quote
RantMachine Posted February 2, 2015 Posted February 2, 2015 Quite probably! My last major project was a £230,000 print run But I figure that if Adobe are kind enough to let people use the fancy toys free of charge for a month, I may as well recommend them! Once you've started using them it's hard to imagine how you ever survived without. I'd recommend giving a trial of InDesign a go for your product brochures, the layout tools are much more refined than Photoshop and the way it pulls together all the elements you've created in PS is really cool Quote
Bogof Posted February 2, 2015 Posted February 2, 2015 Quite probably! My last major project was a £230,000 print run Are you a counterfeiter? Quote
