Low revs/idle running rough, fine higher revs
Hi,
I've got an 03 GSF1200 SK. It seems to have developed a really rough low rev and idle. I've noticed the choke no longer revs up like it used to, just sits at its usual idle. I can smell fuel more than usual as well.
Thus far I've changed all 4 spark plugs as well as an oil change.
Not sure if its related but the other day it ran out of fuel and I had to ride to the garage in reserve. Switched back to regular once I'd filled up.
Any suggestions?
Quick update: went and started it just now and notice that one of the downpipes isn't as hot as the others. As in, I can actually touch it whereas the others are far too hot to touch!
