Hey all,
im touring the pyrenees in less than two weeks everything on bike is rosey , EXEPT when i leave my bike ticking over in garage temp guage goes up and van kicks in as should ,, when im out riding the temp guage does not work stays unmoved ,, before anyone sais , this is not because im moving and engine is staying cool as it used to go to around running temp ( now the big question ) wil my van kick in without the temp guage working im assuming they are separate in which case i shant worry about the temp guage to much ,,, i have triumph daytona 1200 ,,,, and i will be in a hot country safe riding
Have a ride round your local town and see what happens..... :wink: It doesn't take much 30mph or less riding before the fan on my Speedy kicks in....... :wink: My bike is EFI.......so all that stuff is controlled by the ECU.......dunno about the older Triumphs...... :?
The gauge and fans run off separate units, no?
Have you had a jiggle of the wiring?
Not to cause any concern but if you thermostat is stuck open (or removed) and your gauge is a bit jiffy (like mine is), it can look like you're not heating up that much.
