Hi Guys,
TLDR Version:
-Speedo working for 6k miles (My ownership period)
- Front tyre changed by mechanic
- Went over hard bump a day later and speedo and odometer stopped. Tacho still works.
- took front wheel off, replaced the plastic speedo rotor with new oem as old one had 1 of the 4 plastic lugs missing. (Speedo is electronic rather than shaft driven)
- Speedo still not working. Tacho still working.
I think you guys get the jist there. This leads me to believe that it may be a cable or connection issue.
Anyone who has owned an sv 99-02 or who may be a mechanic, do you have any advice?
There are so many cables, none of them seem obviously damaged. I don't have a volt meter to check voltages.
Any ideas?
Thank You
Check you don't have a loose connection anywhere before you get cracking with the volt meter.
