Classickid21 Posted November 5, 2015 Share Posted November 5, 2015 Hey guys sorry I haven't done a forum for sometime. my partner has been in and out of hospital Stressful times things started to chill out again, I purchased on ebay 1st November this year two Honda NSR's both missing too much, I have broken the jc20 alcasta bike up for parts to sell back on ebay. so I can fund the jc 22 foxeye model.personally I love to restore bikes but I am thinking on a low budget I may just rebuild the engine, rat the bike or street fighter Any opinions ?Rebuild the engine it has a 150 cc crank in the bottom end from what I can see it needs big end and seals, top end is 65.0m polini big bore I may go back to standard to keep the funds down and restrictions of new laws. back to a 54.0mm barrel having a 150cc crank and a 125cc barrel Would this cause any problems not too fussed about going fast its just a project toy to do up this winter. barrel needs a replate no matter what any places any one can recommend..? Honda jc20 frame I did all my home work before buying but! 12 digit Vin number ??? is this common 1980's ? every vin checker on line is 17 digit I tried to decode it online not sure if I should put the numbers online but I am not aloud to ADMIN PLEASE LET ME KNOW ILL REMOVE THEM Hi-Jc20*205095* Quote Link to comment Share on other sites More sharing options...
eastanglianbiker Posted November 5, 2015 Share Posted November 5, 2015 by the time you rebuild or replace the crank/big end /conrod assembly and the barrel with new piston kit it would work out cheaper to buy a standard engine that is known to be good Quote Link to comment Share on other sites More sharing options...
Classickid21 Posted November 5, 2015 Author Share Posted November 5, 2015 by the time you rebuild or replace the crank/big end /conrod assembly and the barrel with new piston kit it would work out cheaper to buy a standard engine that is known to be good nickel plated poxy bore £££ £125 for a replate £29-35 for Makita piston Genuine Gasket set £45 crank £205 local shop strip replace con rod rebalance etc seals £35 it all adds up... engine online Varies from £300-350 and there are only a couple floating about.Debating on breaking this one too and with the funds I make buy something else. its not Economical to fix needs Cdi Carb servo full pv bits the hard bits to find Head light, lock set rect/reg coil rear tyre plus rebuild etc... Quote Link to comment Share on other sites More sharing options...
