hardleydavidson Posted July 12, 2016 Share Posted July 12, 2016 Hi,I'm swapping out my old chinese rusty as hell handlebars for some Triumph ones however, the old bars have welded brackets to take the indicators and speedo. I searched high and low but I cant find any brackets or adapters that would suit. All the 22mm ones I have found would fit the bars but the indicators would be sticking up or down, what I need is for the holes for the bars and the indicators to be on the same plane (if that makes sense).Anyone seen anything like this, it's pretty hard to explain Quote Link to comment Share on other sites More sharing options...
JRH Posted July 12, 2016 Share Posted July 12, 2016 Can you post a photo of the existing set up? Quote Link to comment Share on other sites More sharing options...
JRH Posted July 12, 2016 Share Posted July 12, 2016 Or are you after something like thishttp://www.aliexpress.com/item/CC-002-CR-Motorcycle-1-Inch-Chrome-Dual-Throttle-Clutch-Cable-Clamp-handlebar-For-Harley-Sportster/32467613146.html" onclick="window.open(this.href);return false;Oops its for 1" bars Quote Link to comment Share on other sites More sharing options...
hardleydavidson Posted July 12, 2016 Author Share Posted July 12, 2016 Yes that's exactly the thing but I need 7/8 not 1" guess I could use a shimYep that's what I'll do, nice one Quote Link to comment Share on other sites More sharing options...
Guest Posted July 12, 2016 Share Posted July 12, 2016 Yes that's exactly the thing but I need 7/8 not 1" guess I could use a shimYep that's what I'll do, nice one Just take some of the material off the flats of the clamp.You won't see any marks or shims then Quote Link to comment Share on other sites More sharing options...
