I have just got a varadero xl125 2006 I need to replace the starter motor on the bike but having issues locating it
if any one could tell me where abouts on the bike it is it would help a lot
Hi and welcome, starter motor fitted at front of engine, remove from l/h side of engine, may have a small plastic cover over it.
thanks found it
second part to this if it's stuck what's the best way of getting it off the bike if it's stuck as I'm not 100% on trying the heavy handed approach just yet
hi, they shouldn't really get stuck, take out the two bolts on l/h side of motor, then just wiggle it free pulling to l/h side, if you have any w/d forty, then spray close to r/h end where it goes in engine, may help O ring, to loosen up. ok
That's all sound advice but the motor is probably driving a little sprocket and chain that is presumably concealed beneath an engine side casing. This will have to be exposed for reassembly so its probably best to have a look before pulling the motor out just to get an idea where everything sits.
Right, ignore that , I've had a look at the parts drawing and it looks like its all gear driven so no loose sprockets or chains to worry about as far as I can see. So wiggle and pull like Oldgrump correctly advised.
