Cb500 clutch cable
Hi ive recently bought a 1998 Cb500. Unfortunately it wouldnt fit through my gate, so i raised the handlebars by 30mm which in turn put too much tension on the clutch cable. Ive adjusted the clutch cable right off and re-routed it, but there is still too much tension on it as there is no free play. All i need is for the cable to be an inch longer and it would be fine. Ive looked online and all i can find is standard cables. Has anyone experienced this before? Does anyone know of any slightly longer cables, maybe from a different model with the same connections that would fit? Thanks, Mark.
  • Sign up now
