Honda shock absorber
fifthwheel
Hi all, I have a Honda 125 Pantheon I am doing a few jobs for the MOT.
The rear adjustable shocker is seized. It is dry and working fine but cannot be adjusted is this a MOT fail? thanks John.
If it cannot be adjusted because of corrosion, it is a fail.
"..... a rear suspension component which is:
a. loose, cracked, excessively bent, misaligned or excessively corroded"
Here, have a look - you might find it useful:
http://www.motuk.com/bike/2-4.asp#Menu_Top
Have fun.
If it's not obviously corroded, leave it.......if the shock is still working, then the tester would have no cause to try to adjust it.
Ok will do, I thought perhaps if a passenger was to be carried the tester might say I couldn't adjust it and fail the bike.
Will leave it and go for the test.
  • Sign up now
