Hey everyone
I'm new to the forum but looking for some advice
I've taken an engine out of a KTM 450 SX-F and I'm redoing the fuelling system so I can put the engine in a car
It's a single cylinder returnless system and I don't want to use the stock fuel pump, would prefer to use a third party one! (+ pressure regulator + filter)
Has anyone ever replaced an in-tank pump with an external pump on a returnless system? Any advice would be so useful!
Cheers
Sophie
If you use an aftermarket pump and a separate regulator you will need a return.
Is there a reason you want to replace the OEM pump?
Also, is it carb or FI?
Really?
Why do you "want to put the engine in a car"?
Is it to take it to the tip?
Just asking.
