Mattt Posted June 22, 2019 Posted June 22, 2019 Bought as a bare frame and lots of boxesEngines complete at least and was running As I didnt take it apart its a struggle to make sure each bolt is the correct one Hoping someone on here has one and some decent pictures of it or has one stripped down a little ,fairings off etc CheersMatt Quote
Bianco2564 Posted June 22, 2019 Posted June 22, 2019 Yay, another RGV Yes I have a VJ22, owned it for 6 years and much like you bought as a pile of parts.There is a dedicated RGV forum run by a guy called Sean who owns a company called The Tuning Works, he sells almost everything for them.Had my barrels replated by him last year.Got plenty of pics of it in various states of build.Suzuki also have the RGV on the vintage parts scheme.Things to check;Frame not cracked around lower suspension mount.Power valves have a nasty habit of falling into the cylinder and colliding with the piston, make sure you inspect them before you run it and every year or so.3 piece pv on VJ22 is the worst.If you don't know the history of the engine its advisable to take the barrels off and inspect the nicasil liners,pistons and crank bearings.Only use top quality 2 stroke oil,I use Castrol power from Halfords.Warm it up before riding off Quote
Mattt Posted June 22, 2019 Author Posted June 22, 2019 Thanks for the info, mines a VJ21Its a import that came with a spare Uk frame and uk speedo,the engine has only 7k kilometres on it Bought off a mate so epthe engine was ok,took one head off to check for any damage or rustMain problem is identifying the correct bolts,length,head shape etc , as these are usually hard to spot on any online photos or build threads ,even cmsl lists dont show the bolts Quote
Bianco2564 Posted June 23, 2019 Posted June 23, 2019 Just checked in the Suzuki genuine manual and the doesn't mention bolt lengths or style, just torque settings.I had to replace most on mine aswell, luckily I have amassed a collection of fasteners over the year's and had most suitable "in stock".Depends on how original you want to be.I used capscrews on the engine for convenience and a variety of plated hex and cap heads across the rest of the bike. Quote
fastbob Posted June 23, 2019 Posted June 23, 2019 Sometimes I find that parts diagrams can be quite useful in figuring out what goes where . I don't know what year yours is but here's a link . https://www.cmsnl.com/suzuki-rgv250-1993-p-e02-e04-e21-e22-e24-e34_model14009/partslist/#.XQ9fG2nTWyU Quote
Mattt Posted July 7, 2019 Author Posted July 7, 2019 HiNot really ,bolted a few small parts onto the frame ,forks are back on Probably either start on the engine cleanup or repaint the wheels and put the tyres on next Its going to take me a year or so,as I just do a little each month amd slowly it will get there.The 916 i bought in boxes took me 18 months Luckily someone off this thread has one ,and sent a photo of the last part I just bolted on which is handy Quote
