noctrl Posted September 20, 2019 Posted September 20, 2019 Good morning All,I had this issue last year and with the change in weather it has returned; the indicators on my Honda VFR800Fi are temperamental on cold mornings/evenings. The switch itself isn't sticky, but when actioned there will often be no indicator action for a minute, then the relay clicks and off they go. Sometimes I get a single click then back to nothing.Given this only happens in the cold weather my thoughts are a sticky relay more than anything else as will be original (2001). Any thoughts before I swap out replacement? Quote
oldgrump Posted September 22, 2019 Posted September 22, 2019 Hi [mention]noctrl[/mention] , I've been using Vfr 800 for year's now, and some winter's mine play up, I just keep spraying the inside of the switch with electrical spray, and that normally sorts it out.Never replaced the relay. Quote
Mississippi Bullfrog Posted September 22, 2019 Posted September 22, 2019 I had that on one of my Honda's years ago, some switch lube did the job. Not WD40 as that is only a very temporary fix and then it makes things worse. I used bike spray with teflon. Quote
Grumpy Old Git Posted October 6, 2019 Posted October 6, 2019 You can get 'Contact Cleaner' which works really well - Maplins used to sell it Quote
