Hi all,
I have a question regarding electrical accessories on our bikes batteries. I have a 12v socket aftermarket as most people do. I am planning on installing heated grips and a hawk alarm system i bought years ago and never used it on any previous bikes. My battery is less than a year old and the bike in question is my suzuki rf900. Will i need to upgrade the battery to a more modern lipo/ion to use all these accessories, the alarm will obviously not be in use ehile riding. This is my everyday bike and will be ridden everyday (well once we get back to work atleast) commuting and my weekend bike atm while i rebuild the other.
Regards, Eric.
:stupid:
Connect the heated grips into an ignition controlled circuit so they can not be left on.
Posted (edited)
Personally owning a bike with an alarm not certain I would do again.. that's just personal choice.
Other choice would be to run everything through a relay. One wire to inhibition controlled circuit the test can then get power direct from battery...
Edited by onesea
My Oxford heated grips have an 'intelligent' controller which senses the when the engine is off and they turn themselves off after 3 minutes. They're connected straight to the baterry terminals.
Never had a nasty surprise!.
And my grips, but being an electrical engineer I don’t trust electronics. Mine are wired through a relay. :wink:
  • 2 weeks later...
. So do mine. Didn't work. After 2 flat batteries I wired then to a relay.
To the OP, its not the battery that makes the power its the alternator. Generally you are fine.
